Results 1 to 3 of 3
Thread: Gerabox cooler lines
    Vs Berlina
    Mar 2009
    Default Gerabox cooler lines
    Hi again. Has anyone swapped a hdd7 for a hdd6, my concern is the coolant coupler. Will the part of the coupler that screws into the housing swap over or are the threads different?
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    do you mean the brass union? if so then the answer is yes it should fit fine.
    Vs Berlina
    Mar 2009
    Thanks. Yes. The 6hdd has smaller cooler lines/coupler than the 7hdd, I'm hoping the connection with the gearcase is the same size.
  1. 304 Vac Lines
    By fu2 in forum V8 Development and Modification
    Last Post: 28-05-2009, 11:07 AM
  2. Undoing Cooler Lines
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2008, 11:46 PM
  3. oil cooler
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2008, 01:53 PM
  4. V8 Trans cooler lines
    By broderikb in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-06-2006, 10:03 PM
  5. oil cooler
    By VNCommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2006, 11:15 AM
