Results 1 to 3 of 3
Thread: vr problem
    38VNIT's Avatar
    38VNIT is offline Azerium
    nothing
    Jul 2006
    Inverell
    Default vr problem
    i brought a vr wagon yesterday,
    washed the engine bay this mronig and now when it revs hard it has a fluttery type miss in it, im not sure if the coil pack was just old or it has sucked in to much water, and i checked all plugs and leads etc, and let it dry before driving
    If you do things righ people wont know you have done anything at all...
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    leave it in the sun for a while... and maybe leave it running for as long as you can to produce some heat through the engine bay...
    VS Series II
    Nov 2007
    Newcastle
    I done a degrease on my VS a few weeks back, had a similar problem.
    After replacing, plugs, leads, checking coils, oxygen sensors, wd40ing every electrical connection I found - it turned out to be the fuel pump. try all the cheap things first - esp wd on the elecs just incase.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VS Ute PROBLEM!!!!!
    By Leathal11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 10:31 AM
  3. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. serious problem
    By fastvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2005, 11:18 PM
