Results 1 to 13 of 13
Thread: auto problem plz help ???
    94 VR BERLINA
    Feb 2009
    Default auto problem plz help ???
    ok 1st ive been having this problem for about a month when the gears change from 1st to 2nd it kick
    eg the car revs out to about 4000 then changes lunging u back
    then the car begings to jolt
    eg when i put my for on the peddle lightly it revs to 2000 then starts to speed up what problem and how much to fix oh and my auto oil has slightly turned brown and has a light burnt smell.
    any iders what it could be if not
    how much for a reco auto ?
    other problems i have atm
    i have a vacuum leak to the auto
    just fixed alternator ezy fix lol just sanded bushes a little
    i have a fuel leak from fuel rail to throttle body and fuel pump
    diff needs looking at
    thanks guys
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    94 VR BERLINA
    Feb 2009
    Vr Executive 3.8
    Dec 2008
    The auto sounds like its on its last legs, take it very easy on it to avoid being stranded. A new reco auto is around the 2k mark plus or minus a few hundred depending where you go. Fuel leak not to sure but I would say its the o-rings?
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    was the oil low when you checked it and what is the vacuum leak, more info, diff and trans are usually the same place so drive in to one and see what they say.
    VS Acclaim
    Nov 2007
    Mate ive had the exact same problem with auto since i got the car (2years ago) unfortunately its just on its last legs, but you could just try getting a tran service and see if that helps
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    check your auto followong these steps...
    TRANSMISSION FLUID CHECKING PROCEDURE
    1. Start engine and drive vehicle for a distance of 24 km, or until transmission normal operating temperature is reached.
    NOTE:
    As temperature greatly affects transmission fluid levels, this operation must only be carried out with the transmission at normal operating temperature (82 - 94° C). If the vehicle is not at normal operating temperature, and the proper checking procedures are not followed, the result could be a false reading of the fluid level on the dipstick.
    2. Park vehicle on level ground.
    3. Move gear selector to 'PARK' position.
    4. Apply park brake.
    5. Let engine idle for 3 minutes with accessories turned off.
    6. Lift the locking lever on the red coloured dipstick, remove dipstick and check fluid colour, condition and level.
    7. If the fluid level is low, add only enough Dexron® III to bring the level into the “HOT” area.
    * Inaccurate fluid level readings will result if checked immediately after the vehicle has been operated under any or all of the following conditions:
    a. In high ambient temperatures above 32° C.
    b. At sustained high speeds.
    c. In heavy city traffic during hot weather.
    d. Towing.
    e. In commercial use (e.g. taxi).
    * If the vehicle has been operated under these conditions, switch the engine off and allow the vehicle to 'cool' for approximately thirty minutes. After the cool-down period, re-start the vehicle and continue from step 2, above.
    goodluck...
    VQ Caprice II
    Aug 2006
    cheapest fix would be to have it professionally serviced, changing the filter and full flush of the converter and oil pan. On VR's the change is accomplished with electronic selenoids as such they can stick and cause what you are describing.
    Cheapest repair would be wrecker swap out, in Adelaide you can get one for around $350 that is in very good condition.
    Fuel Leak ?? - more information is required to solve.
    Vaccum Leak to the Auto?.... Again more information plz
    Thanks
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    Quote Originally Posted by S2_VR_ View Post
    NOTE:
    As temperature greatly........................................... .................
    This isnt necessary just to check you oil, its not a space ship, once the car is started, drive around the block, pull the dipstick out and check the level, if it low, top it up. Keep the car running too. Dexron III might be a good oil but what a lot of people dont realise is it has cleaning agents in it. Once this is used in an old auto, it frees up a lot of crap buildup which sticks solenoids and causes more problems. Its only good to use once the box has been rebuilt, regulary serviced or a newer car which cannot builup that much crap in a short time.
    Get a service, filter, oil, adjustments and see what happens, and go to an auto joint.
    94 VR BERLINA
    Feb 2009
    thanks guys
    oh and today i just realized that when the car is cold the auto kicks and shit but as soon as the auto heats up it stops and it works like a dream the kick is very slight can just feel it could it just need a service?
    Vr BT1 5lt
    Jul 2009
    Frankston
    94 VR BERLINA
    Feb 2009
    Quote Originally Posted by bigmicky22 View Post
    hey ipsy where in oz are you???
    ive got an auto tranny here out of a vs
    yer im in Victoria Melbourne
    Vr BT1 5lt
    Jul 2009
    Frankston
    i dont know the exact condition of this tranny but may get you out of trouble for a while
  1. Vl auto problem
    By DONHOMER in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-02-2010, 09:29 AM
  2. vs auto problem
    By old8s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2010, 01:52 PM
  3. VR auto problem
    By rodney3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2009, 08:03 PM
  4. problem with auto
    By KingCoMMoDore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 08:34 PM
  5. VY auto problem
    By keithVYSS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-10-2004, 11:11 PM
