Results 1 to 3 of 3
Thread: Pump Fuel
    lilzen96's Avatar
    lilzen96 is offline lilzen
    94 VR Ute S Pack 5Ltr
    Jan 2008
    Darwin NT
    Default Pump Fuel
    Hi i own a vr ute and am currently stroking the motor out to a 355. i was just wondering what how the car will run on pump fuel as my compression ratio will go from 9.0:1 to 10.5:1?
    THEY SAY APPLYING LARGE AMOUNTS OF HORSEPOWER TO THE REAR WHEELS OF A STATIONARY VEHICLE CAN CAUSE PROBLEMS ............................ ONE MANS PROBLEM IS ANOTHER MANS PLEASURE
    pjdm1980's Avatar
    pjdm1980 is online now The Holden Hunter!
    Feb 2009
    Geelong, Victoria
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    it will run on pump fuel, its more about how the tune is, if its tuned perfectly u 'could' run it on 95ron, but most likely u'll be running on 98ron.
    the tune is the key.
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
