Originally Posted by
Smallies
You guessed it.
Interior electrics.....
So far i have listed:
Fog lights don't switch on
check your fuses, and bulbs otherwise could be switch, check for power with test light.
Climate control only occasionally switches on
This usually means your relays are shot.
Head unit always blows fuses
Bad earth? or speakers earthing on body?
Drivers door lock wont go down with button
replace central locking module and WD40 the key barrel, same part as commodores so cheap fix, you will need a hex screw driver bit to remove lock, and experience with door trim removal
passenger seat up/down movement doesnt work
if they are electric check again for power with test lamp
Rear window wont move at all
check for voltage, otherwise replace motor, easy to do, just need to get yourself a drill to remove rivetts, and some new rivvetts to replace motor
Front window comes up extremely slow
this would be the rubber nearest the hinge, just wind window down , look into cavity of window and then you should see if the glass is on the rubber or on the outside of it, replace re-fit as necessary. Common Fault with all commodores, a bit of strong weather strip glue when fitting will help here.
