Results 1 to 14 of 14
Thread: Series 2 Flywheel...
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    Exclamation Series 2 Flywheel...
    hey guys..
    was the Series 2 T5 Flywheel 8 bolt?..
    or 6 same as series 1??
    VS Berlina 3.8
    Dec 2008
    You mean from a VN?
    As I understand it, only S1 VN's were 6 bolt, VN S2 and up were all 8 bolts.
    Feb 2009
    ahh true... wel im good anyway... i got a 8 bolt... it's for my VR so all good..
    what about fitting a T5 to a VS? wats the deal there? does it all go together? do you just need to change the ECU?
    VS Berlina 3.8
    Dec 2008
    S1 VS's had the T5, only S2 VS's had the Getrag.
    Converting a VS is the same deal as converting VN-VR, so you will need to do everything mentioned in the manual conversion thread, so yes you will need a new ECU (as well as everything else). Not sure how much of a difference there was between the VR/VS flywheels though.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    its been mentioned on here allot that on a VS you will need to get the manual flywheel mirror balanced to your auto flexplate.
    What I want to know is will an auto flexplate from any ecotec do for the mirror balancing? and anyone know of what type of places would do the work or better yet a place in Melbourne?
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    What does the flex plate have to do with anything? The flex plate gets replaced with the flywheel.
    VS Berlina
    Feb 2007
    Quote Originally Posted by maldotcom2 View Post
    If you have a VS and are using an older manual flywheel, it has been said that you will need to get the manual flywheel mirror balanced with the flexplate.
    I.E your flywheel would have the same balancing as the flexplate did.
    This is because the ecotecs are balanced differently then the older "buick" engines.
    So thats what it has to do with anything :P
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Correct^. The ecotec is 'internally balanced', so the flywheel/flexplate has a perfect balance. The buick is 'externally balanced' so the flywheel/flexplate has an offset balance.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VS Berlina
    Feb 2007
    Thanks Azz, any chance you know of a place in the easturn burbs that does this sort of work? or what kind of places I should start looking at? I have a VN S1 flywheel to go on my ecotec.
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    No worries. Umm cant say I know any places. But the offset weight is that small risen part on the back of the flywheel. Dremel?
    My (ex)Ride
    VS Berlina
    Feb 2007
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I wouldnt think so. The goal would be to make it the same as the rest of the flywheel. The alternative would be to add weights to the opposite side, and anywhere needed to get a perfect balance. Kinda like balancing a wheel. Speaking of, an old wheel balancer that uses a bulls eye level might be of aid.
    These are just ideas that are popping into my head btw.
    My (ex)Ride
    Dec 2008
    Fair enough. I didn't know about that. So that would mean the flywheel could only be bolted onto the crank one way. When i did mine i just bolted it straight on. Maybe next time i do the clutch i'll see about this balancing.
    VS Berlina
    Feb 2007
    if I find a place ill let you all know.
  1. v6 series 2 flywheel 8 bolt
    By eaton v8 in forum V6 Development And Modification
    Last Post: 18-08-2008, 04:07 PM
  2. WTB: Series 2 Flywheel...
    By Chirpstr in forum Swap / Wanted to Buy / Trade
    Last Post: 15-07-2008, 01:12 AM
  3. Help!!!! I Need A Flywheel 1998 Vt Series 1
    By vt1998 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-07-2006, 09:03 PM
  4. series 2 flywheel
    By Wonderboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2006, 09:11 PM
  5. Series 2 flywheel
    By Rhino Racing in forum Parts And Other Items For Sale
    Last Post: 30-10-2005, 09:39 PM
