hey ppl, on a cold engine my vs struggles to change gears. reving out with no power also changing from drive to reverse the engine sometimes cuts out, but once driving for a few k's it runs fine.. any advice thanks
Check the fluid level in the trans as it may be low or need servicing - you can do a service yourself if you are keen. The throttle body and IAC may be dirty and need cleaning as well. See the "how-to" section for details.
