Hi guys,
i hav check'd and gone ova just about everything and still stumped.
My son took the car out and it just cut out, he put in2 neutral while rolling and tried to start, it didnt, pull'd up and tried starting again...nothing.
with the car on stands is the auto stuffed if back wheels move with every shift, including park??
thanx heaps for any input
Lynn.![]()
Do a codes check: Checking error codes VR/VS (Revised)
That may indicate that the CAS is faulty.
The trans is not stuffed if the back wheel still turns in PARK with only one wheel in the air and the other on the ground. Both wheels off the ground is no indication but apart from that the PARK function is mechanical and even 101% stuffed trans will still have the PARK function.
Thanx for the input........... cant do codes check as power disconnection wiped it, ive even tried the ..try start 20 times to get a read but didnt work, had both back wheels off the ground at same time to check if stuck in gear u kno manual move selector, i will 2mrw try another ECU and try to manually turn engine, if dat fails..... mayb internal????
