hey guys ive taken my dash off to replace the globe in the speed alert for the light.but i cant find it.anyone know where it is and how to get to it?
cheers
so you have taken the dash fascia off, if your speed alert is mounted into the facia the globe will be that black thing in the centre of the circuit board sticking up, just gently twist it and pull it out.
If you are referring to the globe in the cluster, your only two more screws away.
ive tacken the dash facier off
and behind where the speed alert is theres only 1 thing going into the back of it with wires that actually makes it function. there is no globe with it.
ive looked and ive found the hole..but is there supposed to be a wire or globe comeing out of it?
because there isnt..
look inside youll see a black or white? socket that hold the globe in. get a small screwdriver slot it in and twist and pop it out. You should be able to tell if theres no globe at all in there.....
