Well im droping the wagon tomorrow and need to know how to set up the adjustable panhard bar any help would be great BTW I have no idea how low the springs are just know there low lol
is it an on car adjustable one? they are easier to adjust. when i did mine i just kept adjusting it until the gap between the top of the tyre and guard were the same on both sides.
Yeah i think it is can you adjust it with the wheels on ground or do you have to jack it up so the wheels are off the ground
You can remove the panhard rod (standard rod and height) with the car on the ground. In saying that you should now know what to do.
If not, remove the standard rod, then install new rod and adjust so its not pushing or pulling in either direction.
wheels need to be on the ground.
well not on the ground. an easy way to do it is. jack up the rear of the car. chuck a stockie under each tyre and let the weight be on the wheels.
then you can climb under and adjust your panhard rod. and check clearances etc.
shouldnt be too hard mate. i took mine to pedders and they charged me 20 bucks to adjust it for me. because the nut was stuck and i cbf doing it
hey guys just wondering do you need an adjustable panhard rod if one side is lower then the other (non-irs) to make them even? Cheers
Thanx guys for the help I just didnt know if I could adjust the panhard bar while it was on the axle stands or if the rubber had to be on the ground but I've got some stockies out the back so ill sit the car on them thanx again
