Results 1 to 7 of 7
Thread: VR Statesman V6 sensitivity switch power steering into VR Berlina
    pjdm1980's Avatar
    pjdm1980 is online now The Holden Hunter!
    Feb 2009
    Geelong, Victoria
    Default VR Statesman V6 sensitivity switch power steering into VR Berlina
    Can you put the VR Statesman V6 sensitivity switch power steering rack into VR Berlina?
    or is it just way to big of a job because i have to replace my pack anyway.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    VS Berlina 3.8
    Dec 2008
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Nope just statesman's and caprice's and then later on vs calais's
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    That's what I'd like to know. all i can tell is that it has a electronically controlled pressure switch that makes it easier to turn the steering wheel at low speeds, but I'm not sure if it's controlled by the computer and if i need a statesman computer or can i just use the standard.
    VP Exec
    Jun 2005
    The variable assistance is achieved by varying the flow of fluid bled from the rack back to the pump. The "switch" on the rack tower is a solenoid valve that controls that flow of fluid.
    The level of assistance is determined by the BCM in response to road speed and altered using a pulse width modulated (PWM) signal to the solenoid.
    The BCM's are specific to models with the system.
    The power steering pump outlet is also different but is easily swapped.
    The only difference between the two types of rack are the rack towers.
    Swapping in a higher level BCM, to operate all the functions the current one does as well as the steering, could probably be done.
    Another way might be to piggie back in a variable assistance BCM only to operate the assistance solenoid.
    Given some electronics ability I guess it wouldn't be too difficult to take the speed sensor signal and generate a PWM signal out using a custom circuit.
    There was a discussion on here some time ago re. altering the signal with resistors to increase the steering weight. That included some info. on how it worked. Probably worth a search.
    Link: Calais variotronic steering modifications
  1. VS Statesman Power Steering
    By douge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2009, 09:07 PM
  2. WTB : Power window master switch for VX berlina
    By thekow in forum Swap / Wanted to Buy / Trade
    Last Post: 15-06-2008, 03:53 PM
  3. Replies: 0
    Last Post: 15-04-2007, 10:35 PM
  4. Power Steering vt series 1 berlina
    By Vt-Brrrlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2006, 10:35 PM
  5. vx 01 berlina power steering/pump? pulsating
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-04-2005, 06:17 PM
