Results 1 to 11 of 11
Thread: VR 304 not starting when warm
    Jun 2005
    Default VR 304 not starting when warm
    had an issue the other night where my car wouldnt start. i was driving it 20 minutes before and it was fine. stopped the car, came back later and it would just crank and crank, with the occasional tiny fire and then nothing. tried it today and it started up first go. what could cause this?
    it did something similar last week, where it stalled while driving, then wouldnt start up again. but i got that fixed by fiddling around with the earth wire on the alternator
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    vs ss series 2
    May 2009
    could be the coil on it way out happened to mates vs 5 ltr on the high way we thougt it was the silver box on the side of the strut tower but ended up being coil
    hope this helps
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    If ya got a spare coil around i'de be throwing that in just in case. Why not start it and let it idle outside for a while then try and repeat the fault. If you can then good you can start fault finding on it and id be going for spark first. Could be fuel pressure related too but less likely and less again would be the injectors not firing.
    Reaper
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    if its cranking good, it would only really be coilpacks or fuel pump, I would go coilpack first
    Jun 2005
    hmmm the coil and the distributor are both around 9 months old, so im hoping theyre not causing any issues
    VS exec
    Jun 2009
    bong from the gong
    CAS try putting some water on it to cool it down next time it does it, saves wasting money only to find out its something else
    Jun 2005
    Quote Originally Posted by tt460 View Post
    was waiting for someone to mention this. v8 has no CAS
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by stocky View Post
    lol, so true
    Reaper
    simmons001's Avatar
    simmons001 is offline I like VS Caprices
    WH Grange/VS Caprice S1 5.0
    Jul 2005
    Mine did something similar, tho it also stalled on random occasions. Was the hall effect sensor in the dizzy. I'd check as above, but keep this in mind
    VP Executive R-spec
    Jan 2005
    I agree with the above and that's what I told Stocky, most likely the hall effect, but also could the the coil or module. When things break you should allways suspect the newest stuff first, they area allways more likely to break than something that's lasted 20 years and proven itself
    Jun 2005
    found the nut on the starter motor had come loose. tightened that up and havent had a problem yet
  1. problems starting when warm
    By ditch_12 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-06-2009, 11:11 PM
  2. warm air
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-12-2008, 11:56 AM
  3. starting problem when warm
    By scottVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2008, 01:11 PM
  4. trouble starting when warm
    By mon_dave_vl_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2007, 12:44 PM
  5. Mates VN Not starting when warm
    By bsbozzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2006, 09:54 AM
