Results 1 to 11 of 11
Thread: vs s2 v6 central locking
    vs commodore executive s2
    Aug 2009
    Default vs s2 v6 central locking
    The remote central locking works on all doors except drivers door, however if you stick the key in the door and turn it works all doors. I have just purchased a new key and the problem still exists. Some assistance would be greatly appreciated.Cheers.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd say it works on all 4 doors when you use the key in the door because you are then physically unlocking the drivers door and electrically unlocking the other 3 doors. The key is mechanically connected to the lock plus a microswitch that then unlocks the other 3 doors.Sounds like to solenoid is gone on the drivers door.
    Aug 2009
    Shaundy's Avatar
    Shaundy is offline BMW Technician Apprentice
    VS Executive S2 BT1
    Jan 2009
    One simple thing to check is whether there is any dirt in between the lock knob and its surround. I had a problem where one of my rear doors wouldnt unlock and all it needed was a clean out.
    This VS is guarded by shotgun 4 nights per week - You guess which 4!
    My BT1:
    [SIGPIC][/SIGPIC]
    Aug 2009
    Quote Originally Posted by hako View Post
    What is the best way to go about replacing the solenoid as it looks difficult to access?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The solenoid/actuator is part of the lock mechanism so it's easiest to get a direct replacement from a wrecker - make sure they guarantee it to work. It is possible to fit an aftermarket actuator but it involves a bit of stuffing around and I'd go for a direct replacement.
    Removal should not be too complicated once the trim is off - take digital pix as you go so you can remember re-assembly.
    If you like, pm me your email address and I'll scan the page from the workshop manual.
    VS exec
    Jun 2009
    bong from the gong
    I would try giving it a spray with wd40 on the mechanicm, to clean dirt old grease etc out and see if it works then follow up with some chain lube to keep it lubed up
    Aug 2009
    Thanks mate. Email is davidbenjamin70@bigpond.com ,appreciate it,cheers
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    get the CRC or WD onto it..... mine did the same thing (only 2 locked) andi drenched them with the wd and they work better than ever now... give it a go
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Instructions should be at your PC now. If not sharp enough I can resend. Good Luck.
    Aug 2009
    Hey thanks for email ,instructions are clear.I can have a crack at now. Appreciate your help .
    Regards David
  1. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  2. Central Locking
    By RoboticCherry-Coke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2008, 01:13 AM
  3. VP central locking
    By Dazzamcgee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-12-2006, 07:57 PM
  4. Central Locking
    By fatboy2869 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2006, 01:28 AM
  5. Central Locking
    By Nev in forum Electrical Wiring / Questions
    Last Post: 16-07-2005, 01:04 AM
