Results 1 to 20 of 20
Thread: Have i wrecked my new 70mm T/B .... help please!
    RALLIART Magna
    Krabbyball Champion!
    Sep 2008
    Cairns
    Question Have i wrecked my new 70mm T/B .... help please!
    I am replacing my old T/B with a Mace 70mm one..... This is what i have done
    I have snapped one of the torx screws while tranferrring the TPS to the new throttle body ---- it has snapped at the base where it goes in ...... i am extremely pi#$ed off with myself for doing this!!
    Can someone please tell me what options i have to fix this situation or is the T/B now stuffed.
    Can i get away with just one screw (wishful thinking,,, not likely)?
    can i locktite the screw in there or something?
    Any advice is much appreciated...... Thanks
    Josh.
    vr
    Jun 2009
    Tech Tips - Easyout. i think any easy out would be your best bet here mate. failing that you might have to drill out the old screw and tap a new thread to the next bolt diameter. ive posted a link for you on to to use an easy out. hope this helps
    VS exec
    Jun 2009
    bong from the gong
    Have a look in the yellow pages for a a thread repair guy. if you cant find one call a local bolt shop they should be able to give you a number for one.
    RALLIART Magna
    Sep 2008
    Cairns
    Thanks for the replies fella'a
    I gave mace a call .... they gave me some options and also said that it should be fine with just the one screw ... wouldn't be so fine if it was the iac though.
    I installed it like this and have taken the car for a drive..... no issues with idle and no engine lights on.
    Not sure about the 70mm T/B yet ..... it seems i have pretty much lost 1st gear --- jumps out of first into 2nd very quick..... this is resulting in a loss of torque i think. Car does not feel as though it has as much torque down low as it did previousy.
    It does seem to get up and go in the higher revs though....
    Maybe a tune adjustment will fix this .... will have to ask greenfoam or delcowizzard
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Tune adjustment. Always needed with a bigger TB.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    RALLIART Magna
    Sep 2008
    Cairns
    Quote Originally Posted by Cobez View Post
    Yep... hopefully i can get a tune adjustment to fix the problem. Car is very annoying driving without any kind of first gear.
    A number of post's stated that the shift points wont be effected in the vn-vr's ... but defiently will in the ecotec's... anyhow, my shift points are defiantly effected.
    Have PM'ed Greenfoam, so hoping to hear back from him...
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    The good thing about the early ecotec's is that they can be tuned easily. The newer ecotec's series II VT onward had a flashed memcal.
    If you cant get a hold of foamy then try your luck with a local auto electrician, some do tunes.
    Best to get it done before its too late. Or even put the old TB back on until you get the tune.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it will change early cause its at less TPS % to make the same torque the ecu thinks you are driving like a grandpa and shifts early cause its worked of TPS % vs roadspeed.hopefully foam has a tune hes done before for shiftpoint changes then youll be laughing
    RALLIART Magna
    Sep 2008
    Cairns
    Quote Originally Posted by Ozzie View Post
    G'day mate, cheers for reply.
    WHAT --- 'before its too late'!!!! Too late for what? Will driving the car as it is now cause damage to it in some way....
    Think i will put the old TB back on, on sunday ... need to get a new torx screw first though as i snapped one of the tps ones.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    well the auto will be slipping a little from the incorrect TPS value V's power being made it wont like it too much in the end
    RALLIART Magna
    Sep 2008
    Cairns
    Quote Originally Posted by delcowizzid View Post
    Hi Delcowizzid, If foam has his hands full with jobs, are you able to do a tune to fix this problem --- i am also now running the MACE enclosed pod CAI which goes great guns with my old TB and foam tune..... i think you run a pod on a v6 3.8ltr as well.
    I have PM'ed foam so just waiting to here back from him.... he has the tune he did for me on file.
    VP Executive R-spec
    Jan 2005
    I've adjusted the kickdown onthe VN/VP's to suit the early opening before but can't remember doing a VR, however it wouldn't be hard to calculate , just a matter of if it's worth me doing it or not. Maybe quicker to just run the stock throttle ?. If the throttle was the right size for the car you wouldn't have a problem
    RALLIART Magna
    Sep 2008
    Cairns
    Ok... thanks for that. i will put the old TB back on asap then... until i can get a tune adjustment sorted.
    Just took the car out again to pick up the kids and it feels terrible to drive atm.
    VP Executive R-spec
    Jan 2005
    I'll do it if you insist on running the 70 , but I think it's a fairly large mistake running a throttle that size on a car that can't even use all the air a standard one gives. I know it's a good money spinner for mace to sell them but.... I wouldn't, there's not even a gain on a near standard 5 litre
  15. #15
    RALLIART Magna
    Sep 2008
    Cairns
    Quote Originally Posted by greenfoam View Post
    Ahhh Geeez .... i resisted for ages about getting a larger TB as there was plenty of info on here to suggest there is no point ...but... i felt like doing something different to the car that was affordable and gave in..... well there's 232 bucks down the drain.
    I think i will find the thread about cleaning up throttle bodies and do that to my old one and put it back on ---- my exhaust note has gone to sh%t as well.
    OK, i am happy to go with your advice on this one and ditch the 70mm throttle....does seem like alot of unneccasary work when there are no gains to be had .... Thanks for the offer though mate to do it .... appreciated.
    ANYONE WANT TO BUY A 70mm TB... hehe
  16. #16
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if your exhaust note has changed then you must be getting an increase in air going in the engine changing the fuel ratio or it could be a loss in airspeed causing a rich mix but i doubt that rich will normally make more exhaust noise from fuel still burning on its way out the exhaust ports if you lost low down torque its breathing better too and most likely needs some more fuel to go with the air yeas people say they arnt needed but people do gain torque from them you and twin throttles too
  17. #17
    RALLIART Magna
    Sep 2008
    Cairns
    Well i did get wheelspin today when i floored it .... which didn't happen before.... The exhaust note has got much more droney. I think the car is breathing better cause it goes pretty good at high revs .... but it is a very unhappy car to drive at the moment....
    I have an idea ... I am going to put the old TB back on for now, but i do have a spare memcal and would be interesting to get some power figures of a 70mm TB tuned compared to a 60mm TB tuned. This has probably been done but i'll take it as a fun project for myself --- i think it can be more rewarding testing things yourself rather than reading someone else's results --- especially when you havent been into modifications before.
    My car goes great guns with the 60mmTB and foam tune (making the most of my other mods).
    Delcowizzid --- are you able to do up a tune to get the car running well with the 70mm TB (may as well try something with the TB now that i have bought it)
    This way i will have the foam tune if i want to run the old TB.... and can utilize my spare memcal tuned for a 70mmTB.... and one day compare the difference on a dyno (no tracks or even isolated road around here to safely test the car using G-tech -- i know i'll get done)
    Let me know if this is an option.... either here or PM.... cheers Josh
  18. #18
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i do have a tune i did for chr's VR auto with 70mm but he had the vn T700 trans at the time so ide have to mess with the gearbox settings a little im about too fly out tuning so will be away for a week but ill get in touch when i get back
  19. #19
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
  20. #20
    Mar 2008
    Try running it with the standard memcal if you have it handy
  1. 70mm throttle body
    By -Michael- in forum V6 Development And Modification
    Last Post: 15-02-2010, 08:29 PM
  2. wat wrecked car do i need
    By nick_w in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2009, 10:04 PM
  3. wrecked vs
    By VryNeat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2008, 06:18 PM
  4. my wrecked vx 2
    By VY ACCLAIM WAGZ in forum VT - VX - VU - WH - V2
    Last Post: 16-04-2007, 10:53 PM
  5. 70mm Ecotec TB
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2007, 06:19 PM
