Results 1 to 6 of 6
Thread: Band adjustment
    Jul 2008
    Default Band adjustment
    Hey i was wondering can anyone give me a run down on adjusting the bands on a VR autoslush box ?
    Google isnt playing ball and im sick of this trany slipping/shuddering/not willing to manualy select a gear/only going well when its on the gear it wants then when it changes dump to nutrel/ did i mention generaly being a auto retard.
    commodore
    Aug 2009
    australia
    correct me if im wrong but i dont think 4l60e trannys have bands to adjust theyre electronic and always stuff up as soon as you give them a hard time i went through three trannys in my vr
    VS 5LT STATESMAN
    Sep 2008
    G'day your right unfortunately there are no adj on those boxes time for a rebuild or 2nd hand unit
    Jon
    Jul 2008
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    technically you cant, but then again you can get longer pins with a servo kit for the band apply, not exactly a fully custom adjustment but it sort of can be done.
    Anyway looks like its time for a rebuild or good condition second hand, what state/suburb you in?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The trans on a vr is electronically controlled. You can get the PCM modified to increase shift pressures and the speed (or rather the % of throttle opening) at which gears change. However, the best way is to get the trans strengthened and a shift kit installed.
  1. The worst band in the world
    By Philthy in forum Jokes/Humour
    Last Post: 18-12-2008, 09:11 PM
  2. V band clamp
    By Xadous in forum V6 Development And Modification
    Last Post: 13-04-2007, 02:20 PM
  3. Wide Band/ Narrow band O2 sensors
    By michaelw in forum Electrical Wiring / Questions
    Last Post: 09-12-2005, 12:54 PM
