Results 1 to 7 of 7
Thread: more problems
    VRoooom!'s Avatar
    VRoooom! is offline Vroooom!
    VR Executive Series One
    Aug 2009
    Default more problems
    no remote connection in my speaker amp.
    how do i check the headdeck?
    i also got a new alternator, aftermarket VR alternator.
    my old one was a VT
    is it possible that the alternator is to weak for a sub, two amps n 4 speakers.
    maybe get a BT1?
    i dont care bout prices.
    i just want this fixed!
    thanking yoou!
    VRoooom!
    Supercharged Vr V6 Stroker
    Sep 2009
    if you go to your auto elec you can get a bigger alternator that bolts straight on, 100amp is heaps, although with a good battery your old alternator should be fine,
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Unless you are running a MASSIVE stereo then the standard alternator will be fine.
    What do you mean by no remote connection? You have a remote wire hooked up right?
    VRoooom!'s Avatar
    Aug 2009
    its not a small system, but not a big one either.
    12 sub
    2 amps
    4 speakers
    headunit.
    i worked out that my headdeck cant get enough voltage to run a shitty powervox amp
    just gotta replace the amp.
    can you get ungrades on an alternator? like 100w more?
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    there is ur problem mate..
    dont use a powervox amp..
    get a good [but cheap] amp such as pioneer, kenwood, kicker, jvc, etc and ur connection problem is gone..
    powervox is good for a standard system in the old eh/hr/ or in the shed..
    Philthy's Avatar
    Aug 2005
    Chances are if you are using a powervox amp your system isn't nearly big enough to warrant a bigger alternator. You have to be more descriptive of the system - what power (rms) are the amps, and model numbers would help.
    Before you go spending any money, make sure the wiring is all good. Check all your earths, sand them back to bare metal. Check and clean your battery terminals.
    I'm still not sure what your problem is?
    VRoooom!'s Avatar
    Aug 2009
    everyfins fine braas.
    wiring is all good.
    i got a auto sparky..mate of mine to take a look.
    the powervox is a 5600w one rms is 140x4 per channel.
    it sounds good.
    but shitty amps need heaps of voltage.
    and my headunit cant get enought voltage to it..so a good amp will do just that!
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. problems with cam
    By Philthy in forum V6 Development And Modification
    Last Post: 17-02-2007, 06:41 PM
  3. VR V8 ECU problems
    By VRdrift in forum Electrical Wiring / Questions
    Last Post: 11-02-2007, 06:53 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. VX Problems?
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2005, 07:18 PM
