+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 31
Thread: does anyone else have gas/petrol
    SYM35 Guest
    Default does anyone else have gas/petrol
    hey just wondering if anyone else has dual fuel (non ex taxi) and how does it perform
    death-from-above Guest
    jerome_boy Guest
    I've had a fair bit of trouble with the gas. It tends to backfire under load, and that can lead to all kinds of problems under the bonnet (eg blowing your air mass meter to pieces )
    No matter how regularly you get your car tuned and serviced it still backfires. I'm pretty sure I've heard of other VS's having similar backfiring issues.
    All things considered though, the gas is great at times like now, when petrol prices are through the roof
    VSII Berlina
    Jul 2004
    Yea i've had the a few little problems like jerome_boy with backfiring.
    Turned out to be a gas leak, got that fixed and no dramas since...
    Performance side of things? there is a noticable drop in power BUT nothing too dramatic.
    I'm definately glad i have it with the petrol prices these days, and me being on a tight budget as most uni students are, i wouldnt be able to run my car without it
    SYM35 Guest
    annnnd what type of oil do you use do you have to get the lpg oil yer or can i use normal oils cheeeeeeeeeeeeeerrrrrrssss
    VX S Pack L67
    May 2005
    Gas setups are better suited with Pod Filters instead of the stock air box setup, that will solve your backfiring problem.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker vlv8vic W427 vlv8vic W427 vlv8vic W427
    M5
    Mar 2005
    Australia
    VS.080 Guest
    Talking gas is cool
    Quote Originally Posted by samoht
    I got a 5L duel fuel vs calais its goes quite well on gas, but this is due to taking the car to gas research once every six months and getting it tuned right those guys are the gods when it comes to gas.
    lovemyholden Guest
    I added gas to my car (VS 1995) within 4 weeks of buying it. Have the gas side serviced regularly, and it hasn't skipped a beat. Awesome cars on gas. No backfiring problems, except when I had to replace the crank angle sensor, but that's not the gas systems fault.
    If you get quotes, cheapest is not necessarily the best. Do your homework. But whatever you do, get gas!
    deathsminion's Avatar
    deathsminion is offline Chrgd,Coold,Twinthrot'in deathsminion has disabled reputation
    GT42R forced JZA80 Supra and VT Wagon
    Oct 2004
    Yeah, my VR's on gas. Had a heap of backfiring problems, till I upgraded the plugs and leads, and haven't had a problem since.
    lovemyholden Guest
    Quote Originally Posted by deathsminion
    Can you elaborate on the upgrade of the plugs and the leads? Do you mean that they are specifically made for gas vehicles?
    Oct 2004
    The plugs were rather fouled, and the leads were getting old, so I replaced them with Bosch Sports leads. Huge difference. Misfire went away, car felt a hell of a lot smoother. Just better all round.
    lovemyholden Guest
    Good idea. I'll remember that and get on to it for the next gas service.
    Thanks
    kim_08 Guest
    My VS s1 ex i just got converted the other week. Shes going good though missing a little bit i took it back and she was just running a bit lean but shes ok now. Its so much cheaper im saving 30 to 35 bucks a week!! same as everyone else has said only a little change in power
  15. #15
    96 VS 3.8L V6 Commodore
    Oct 2004
    My VS is on gas. Performs fine. Mine goes harder on gas than petrol. And its certainly an advantage in terms of fuel costs. Be prepared to get heads done tho. Ecotec heads aren't set up for gas and will need to get stainless seats fitted down the track.
  16. #16
    HER82's Avatar
    HER82 is offline HERGTO HER82 Executive
    Is not a Commodore... but still GM
    Oct 2004
    Ipswich area.. apologies for being geographically challenged
    I run my 305 - gas for daily driving & optimax for track... have no probs at all either way.
    1968 Pontiac GTO
  17. #17
    VS UTE
    Jun 2005
    Lennox Head
    jerome_boy maybe your car is running too rich...unburnt fuel in exhaust means kaboomy
  18. #18
    95 VR V6 S2
    May 2005
    Cheltenham VIC
    i had a big problem with backfiring on my VR after ages of trying to fix it worked out it was either the plugs or the leads so replace both got special gas plugs and covered the new leads with plastic tubing to stop cross firing which causes backfiring and hasnt done it in 5 tanks of gas
  19. #19
    VS Vacationer
    Jun 2006
    Quote Originally Posted by ntl
    Hi,
    I am thinking of converting my VS to LPG. When I purchased the car a few years back from the dealer they recommended against it.
    From what I have read in these forums, it seems there are not many problems at all as long as the job is done properly.
    If the above work on the heads needs to be done: How soon after the conversion would this need to be done? Is there a set time or something like that.
    Any help appreciated.
    gnol
  20. #20
    VS Exec, VC SL/E V8, 2x Lada Nivas
    May 2005
    ive been having a few probs with mine still am but its due for the 10 year inspection ive changed the heads got them from repco for $550 the pair change over
    1st pic old head
    2nd pic new head
    Attached Thumbnails Attached Thumbnails does anyone else have gas/petrol-dcam0145.jpg   does anyone else have gas/petrol-dcam0141.jpg
  21. #21
    VRII Acclaim
    Jul 2005
    Gas suddenly looks very tempting with the new government rebate. $2000 for anyone that hasnt heard. Meaning it will only cost about $500. You should make the $ back within a few months. But there is at least a month wait by the sounds of it, if not 2, to get it installed.
  22. #22
    VR-S Manual
    Dec 2005
    What about full gass conversions?
    We all know you loose power with a duel setup, but what if you went for gas only, surely then you'd be able to tune the car to take advantage of the gas, Doesn't it run a higher octane ? anyone with just gas care to share there results
  23. #23
    97 VS Wagon
    Aug 2005
    i only just read in the paper this morning that people have been cashing in on changing there cars over to gas in WA. it said that we get $2000 federal govt rebate but then also get a state govt rebate of $1000. a cheap conversion would set you back somewhere in the $2500 region and you walk out with $500 in your pocket, and what your going to save on fuel. pity the waiting list is so long!
    http://www.thewest.com.au/default.as...ContentID=3202
  24. #24
    VS Exec Series II
    Mar 2005
    Quote Originally Posted by proto_vr
    Unless something is out there that corrects it, the problem is that the V6 fires all cylinders until about 600 RPM (?) on startup. Because gas is mixed with air at the plenum chamber, it can lead to the mother of all backfires..
    ..or so I've been told.
    Clacks
  25. #25
    VS Exec Series II
    Mar 2005
    Quote Originally Posted by gnol
    Hi,
    gnol
    I converted my VS at 120k, its now done 255k. I have not touched the engine or run an upper cylinder lubricant. All I do is run the car 20kms a week on petrol.
    All backfires (about 5) have been results of lead/plug failure.
    I say go for it :-)
    Clacks
+ Reply to Thread
  1. E10 Petrol?????????
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2008, 04:05 PM
  2. Which petrol is best?
    By CHARGEDVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2007, 02:43 PM
  3. Petrol
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2006, 05:10 PM
  4. Out of Petrol...???
    By wbd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2006, 10:20 AM
  5. Which Petrol?
    By pooner01 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-01-2004, 11:50 PM
