Results 1 to 4 of 4
Thread: Remote Centrol Locking no Response
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Default Remote Centrol Locking no Response
    Hi Guys.
    Got a VR Berlina. Have 3 Keys, Including a new one, But the remote central locking dose not work. I did once get the boot to open after reseting the car by disconnecting the battery, but still no luck making it work.
    what part controls the remote and where is it? is there something i can clean or reset? i susspect its the receiver since all doors lock and open with the key just fine. I Have had a look on other parts of the forum but cannot find a clear answer :-(
    cheers
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Where did you get the new key head (remote) from? If it's from Mister Minute or equivalent, did you follow the process they gave you exactly? If you didn't then you will have to get another key head.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Yeah i did get it from mister minute, and yes followed instructions, As they say, Open the car manually, lock the door, start the car and idle for 1min, switch off, then try it and unlock the car with the remote. and the process worked fine in the VX when i got one done for it, but not the VR. And as Mentioned the Boot did open once after reseting the car.
    Quote Originally Posted by BlackVXGTS View Post
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Hey Guys, I resolved The Issue.
    I First Discovered the Sercuity system was Off, I Switch to on.
    Then locked the doors while inside, Started the car, Waited a min or 2, Switched off, waited another minite till the arial went back down, then attempted to open with the remote. now the system now works, remote works as it should. So just if anyone has the same problem give this ago.
    Cheers For the help on the forum, Had the idle issue, cleaned the IAC and runs perfect now.
    Quote Originally Posted by edals View Post
  1. FS [VIC]: power arial module and centrol locking module
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 24-09-2008, 06:41 PM
  2. Remote central locking
    By Trav001 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-06-2008, 07:08 PM
  3. Remote Locking,
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2005, 09:21 AM
  4. Remote locking not working
    By gechurch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 05:05 PM
  5. Remote locking
    By VN Shane in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2004, 09:33 PM
