hey guy does anyone on here have gas shocks on their vs wagon?
if so does any one know how much they pump up and go down?
as in i mean when u pump them up with air how much does it raise up and down
any one???
I had some in my wagon. They were too hard and i ripped them out in favour of something less heavy duty. Unsure how much they lift the car as i never had to use them, even fully loaded they only compressed a little. But they were old and dodgy and stuffed i'd say, your experiance with them may be better.
If you want to tow or take heavy loads, bags are the way to go.
I have the Monroe ones in my sedan, They are pretty hard and have the arse up by about 25mm over the front
I went to the servo to use their pump to lower the pressure and had no luck as the Servo's pump wouldn't lower to 8Psi...![]()
how much do they cost?... could i use them with my UL springs? i like the wagon to feel like it's riding on rails.. lol... just curious cause im up for new shocks soonish
no they are gay, you dont realise it till you go too hard. If the rear is to hard it just want to throw you through the front window every time the rear goes over a speed bump and it just feels bad to drive and the rear end feels like it wants to just slide out. If you want to get rid of body roll the best thing you can do is the sway bars and stick with a comfortable shock and spring setup
ahh that hard huh?.. like leaf springs feeling?.. lol
ok the yeah the shocks i have now are good... (when new) they are pretty much wat i want so i'll just stick with them, thanks bud
