Results 1 to 6 of 6
Thread: milky slime in top of motor
    vy calais - vs comodore
    Aug 2009
    blacktown
    Angry milky slime in top of motor
    hello i just got a vs commodore it started tapping so i pulled the rocker cover off and found a heep of milky oily slime clinging to the top of the rocker cover what could that be so far it is not going threw water thanks i done a oil change there was none of the milky gunk in the oil
    pjdm1980's Avatar
    pjdm1980 is online now The Holden Hunter!
    Feb 2009
    Geelong, Victoria
    Could just be condensation (motor heats and cools water rises to the top hence milky stuff) in the rockers.
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Condensation? WTF? Why is there water in the oil galleries? That's not good...
    Seems to be you've done a head gasket. I suggest you get yourself a compression test done at a local mechanic. That will give you a better idea. If you have water in the oil then the oil will loose its lubricating ability and you'll do some serious damage.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    Aug 2009
    blacktown
    Quote Originally Posted by Scooter79 View Post
    the thing is i am not loosing water the radiator levis is staying full
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    same thing happened to my VR. no water leaking, just some water in there from when the mechanic did a high pressure spray...dumbass. i had my inlet manifold gasket changed just to be sure anyway and radiator flush as well. but the tapping...not sure on that one. does it get warmer than normal?
    Aug 2009
    blacktown
    Quote Originally Posted by jimbojones889 View Post
    yeh there is a few times were the temp has gone up to half but it did not stay it droped back down i put a bottle of lift free in it the tapping has almost stopped now so hopfully that prob is fixed
  1. Milky oil, compression test ok?
    By shanna72au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2009, 12:38 AM
  2. vs commodore got milky oil
    By snowy213 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2009, 07:19 PM
  3. Please help Milky oil issue
    By V85000i in forum General
    Last Post: 14-12-2007, 05:54 PM
  4. Milky Oil
    By fjdave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-04-2007, 02:09 PM
  5. brown slime in my radiator!
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2006, 06:05 PM
