hey guys.
up until recently my calais foggies have been working fine. then last week i went through two globes on my right hand foggie.. my left hand foggie is cracked and water may be able to get in. but thats the foggie that is still working
im not sure if its just a shorted circuit? or maybe something different?
just wondering if anyone else has come across this problemmmm
Slammed 5.7 VY calais II tuckin G8 20'z
i'd be checking the the earth and power to the lights. also check that the light itself isn't loose. two main things that will kill globes are bad connections, and vibrations. also over voltage, but you'd be noticing other head lights blowing too
if it was a short you'd be blowing fuses, unless it was in the earth side, then you'd have the light on all the time, cause i'm fairly are they are earth switching.
