Results 1 to 11 of 11
Thread: vs v6 getting rattley
    Oct 2004
    Default vs v6 getting rattley
    hey all i noticed they other day when i was going up a hill from a standing stop i went to take off and the engine started to rattle sounds like its coming from the bottom end its got 205000ks on it is this normal for them?
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    hmm, it all depends on the life of the car i suppose... my first VR had well over 300,000km's (it stoppped on 310,00km's, but we kept driving it for another 4 years.. that was a long time ago and since then the car has been put into retirement)... but even with 350,000km's (estimate) on the clock, it never had any major engine issue's...
    Oct 2004
    so is it worth pulling the motor out and checking or even replacing the bearings? or just drive it till it dies and get another motor for it? its a ecotec if it helps
    Feb 2009
    hmm, if it were me.. i'd drive it till it dies... then grab another engine..... but im not sure how much it'd be to get the bottom end done...
    Oct 2004
    i can do all the mechanical work my self im just chasing up info before i go pulling it out and finding out its something else thats wrong
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe try to find the actual cause of the rattle first as to me it doesn't sound like worn main or bigend bearings - it could be something very simple like plug misfiring or a hundred other things. If the motor was worn so bad that it was rattling it would usually be burning lots of oil and have the oil light on when idling.
    So first you need to give more specific information - like does it use oil, coolant, overheat, what mods done? etc etc.
    Acclaim VS SII
    Jan 2009
    Is your car fairly 'lumpy' when you sit in idle? Cause it very well may be your engine mounts. When I put my extractors on, I replaced the mounts (190000k+ on the clock) and the old mounts where worn down so far the bolt was rubbing against shit. Might be worth a look
    Oct 2004
    it doesnt use oil no mods at all stock engine and shit i havnt changed plugs and leads yet thats next on my list it doesnt idle rough at all
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My guess only, but I'd say you have nothing to worry about. Just for luck, I'd make sure that you are using the recommended 20W/50 oil and not a lighter oil.
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    3 things come to mind. Cam bearing, cracked driveplate or a rattly cat. Or none of the above lol.
    Nzpure's Avatar
    Nzpure is offline VS L67
    1997 Vs Supa6
    Aug 2008
    Christchurch
    Chuck some promar in it and make sure you havn't left a screw driver or spanner on the engine some where, i had a rattle issue turned out i have a 12mm spanner lying on a chassis rail =D did over 2000kms b4 i found it LOL.
