Results 1 to 9 of 9
Thread: Brown Slime in top of v6 radiator
    VR Wagon
    Oct 2008
    Central Coast, NSW
    Default Brown Slime in top of v6 radiator
    Just popped the radiator cap to find a heap of brown slime on the bottom of it and it is coating the inside top of the radiator. Any idea what it is?
    The oil is fine and isn't milky at all
    The transmission fluid is a nice red colour like it should be
    In all my cars i have never had this slime before...
    Josh
    227shanno's Avatar
    227shanno is offline Donating Member
    vy ss 5.7
    Aug 2009
    wollongong
    probly nothing out of the ordinary mate, maybe it just needs a coolant change. radiators on older cars are always full of crap
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Its probably from the radiator cooling system pellets from Holden. Its like bars leaks. Its meant to be there but your actual coolant should be nice bright green ?
    VR Wagon
    Oct 2008
    Central Coast, NSW
    The coolant is green its just got this horrible brown shit in it lol... Thanks for the replies fellas. Much appreciated.
    VZ SV6
    Oct 2008
    Newcastle NSW
    It's the pellets for sure, usually it builds up under the radiator cap (whilst the actual coolant stays green)... also causes the reservoir contents to turn brown as it goes via the cap and epxansion hose
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    yep i would have to agree with the above, definately the pellets. my car hashada full holden service history until i bought it. i changed my coolant without the pellets and the sludgy cr*p has gone.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Sounds more like the trans cooling line is leaking inside the radiator.
    Is the brown crap oily/sludgy?
    If it is then its definetly the trans cooling line. A small split will only leak trans fluid into the radiator. (cooland cant get into the trans)
    VR Commodore
    Apr 2009
    You can get a build up of crap if you mix different coolants too which end up clogging radiators. Always stick to the same brand.
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by crazy.vr View Post
    Never heard of brown slime from mixing coolants. Cheaper coolants can blow manifold gaskets though.
    In which case he would be topping it up all the time.
  1. milky slime in top of motor
    By peeingeye in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2009, 06:01 PM
  2. brown crap in radiator
    By Simonn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2009, 05:41 PM
  3. brown slime in my radiator!
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2006, 06:05 PM
  4. Brown deposits inside radiator
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2006, 06:49 PM
  5. brown vk
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-02-2006, 10:54 AM
