Results 1 to 5 of 5
Thread: Hood Lining
    3.8 VR Executive S2/ Kawasaki zxr250
    Aug 2008
    West Auckland NZ
    Default Hood Lining
    I was wondering if the foam between the cardboard and the fabric on my hood linings nessecary or could i glue the fabric of the hood lining straight onto the cardboard without it falling off
    Federation
    Against
    Rotary
    Tossers
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    you can glue the fabric straight to the cardboard, there have been a few members that have done it this way.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I thought about doing it that way as well but once you remove the foam you are left with a very thin fabric which will mimic the cardboard backing sheet warts and all. The foam acts as a smoother and covers/hides imperfections in the cardboard. I ended up using a very thin felt (no foam) from Spotlight - about $40 wirth from memory.
    VS Executive
    Sep 2009
    ive seen a guy that stapled his sinking lining up in a square pattern. gives a real nice pin-cushion look to it. very easy too
  1. Mystery hood lining problem
    By GTRwilson in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-03-2009, 05:09 PM
  2. vp wagon hood lining
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2006, 08:57 PM
  3. hood lining
    By schadenfraude in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2005, 05:46 PM
  4. RoofSkin | hood lining | That @@#$ that falls down
    By ViperVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2005, 10:34 PM
  5. Hood lining on wagon
    By doog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2005, 11:32 PM
