Results 1 to 6 of 6
Thread: Sticky ignition
    VR
    May 2008
    Default Sticky ignition
    Hey all.
    As the title suggests, I have indeed got a sticky ignition. Prolly one out of every 20 turns, the key'll get stuck in the 'on' position.
    A few months back I dropped the car in to Holden to get a new barrel/ignition-switch. When I got it back, the bloke told me to "watch the ignition, coz' it's sticky & if the key is left in the 'on' position you'll burn out your starter". Well, lo & behold - guess what happened???
    So I've just replaced the brushes on the starter, & now I wanna fix the ignition problem. I'm a bit sketchy on pulling apart the ignition due to all the electrics & immobiliser etc. My dad reckons I should shoot some WD40 down the key-hole, but the idea doesn't sit right with me ... any suggestions?
    Cheers.
    Joe.
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    I wonder wheather its the slides getting caught in the barrel or the switch at the rear hmmm.
    Try lube first as its the simplest task then if it does not yeald results go the harder tasks ,buy some graphite grease (dry glide etc..) as its better than wd40 in the lock because wd40 etc will catch dust and make a mud grease pit.
    Heres some help for the harder options.
    How to remove a stuck ignition barrel VN-VS
    VR
    May 2008
    Cheers bro, legend. So jetting some WD40 down the keyhole wont kill it?
    Whats the deal with the slides and/or switch?
    You'd think holden would return the ****in thing in good order, seing as how they charge like wounded bulls. Go figure ...
    Anyway, cheers dude. Champion.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by joe_rolls_commo View Post
    slides = barrel internals and the switch is the electrical connector at the back of the barrel
    did you keep the receipt/invoice?
    VR
    May 2008
    Na no reciept. I've moved house since then anyway ... otherwise I'd be swinging by the shop to vent my spleen & visit gods wrath on the knob who did it. He'd be changing my ignition, again, for free - with a set of broken thumbs and a rooted starter-motor lodged in his lower colon.
    ...but I digress - I've had a squiz & know what/where the switch is, but it's new - therefore good, right? If I drop it in to a pro, what can they do about it? Will I be up for a new ignition barrel?
    94 VR Statesman
    Aug 2006
    powder graphite i find is usually good for locks dude just put some on the key slowly put it in then just work it... wow kinda sounds filthy but you get the idea
  1. Sticky Steering
    By jacquie8653 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2010, 01:46 PM
  2. sticky accelerator help.
    By innthetropics in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-01-2009, 04:42 PM
  3. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  4. sticky Ps
    By Tom04 in forum General
    Last Post: 16-11-2006, 03:34 PM
  5. Sticky Tacho
    By hertygerty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:42 PM
