Results 1 to 4 of 4
Thread: How to fit VS Boot strut
    VS S2 Acclaim
    Apr 2005
    Default How to fit VS Boot strut
    I need to replace the gas struts that support the boot. How do I go about removing and installing the struts?
    VR Acclaim
    Sep 2008
    Kingsley WA
    Prise off the clip with a screwdriver and pull the strut off the nipple. Compressing the new strut during installation is something I found difficult. When I replaced them, the only way I could get them on was to lay on my back in the boot then by pushing up the lid with my feet to open it as far as I could, and with all the pressure I could manage to compress the strut, I was only just able to get the end of the strut over the nipple. You need someone around in case the boot closes on you, or leave the hatch down on the back seat, IF you can fit through. I was absolutely knackered when I finished. The amount of force you need to compress a new strut is incredible.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    If you remove the rubber bump stops on the boot hinges first you will have enough room to fit the struts without needing to compress them. As the previous post says, have someone support the boot lid while you are lying on your back in the boot.
    VS S2 Acclaim
    Apr 2005
    Thanks fellas. I got some struts of ebay. Was not to hard to install. But the boot fell on my leg once I removed one of the old struts. Needed to be careful. If you remove the bump stops which slide out towards the rear of the car the struts are easy to install
  1. Vr vs boot strut difference
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2011, 12:58 AM
  2. [SA] May Trade: VR Boot with SS Spoiler, for stocko boot.
    By StockoVRWagz in forum Swap / Wanted to Buy / Trade
    Last Post: 04-04-2009, 04:07 PM
  3. boot strut bracket broken!
    By vsdore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2008, 11:28 AM
  4. boot light stays on when boot is closed
    By seans VL Calais in forum Electrical Wiring / Questions
    Last Post: 25-09-2007, 05:17 PM
  5. Broken boot lid gas strut mount
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2006, 09:30 AM
