Results 1 to 3 of 3
Thread: Cooling system reserve tank question
    VS Executive
    Oct 2008
    Balwyn, VIC
    Default Cooling system reserve tank question
    This is probably a stupid question but better to be safe than have my radiator blow!
    There are two hoses coming out of the reserve tank of my cooling system in my commodore. One of them is connected into the radiator, the other isn't connected to anything and is dangling down over a hole. Is this a drainage hose or has something come loose? I don't want to risk blowing the radiator as it is only about a year and a half old.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    no, one hose is just overflow, and dumps water on the ground if you overfill it as far as I know.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS Executive
    Oct 2008
    Balwyn, VIC
    Quote Originally Posted by Vee-ard View Post
    Thanks mate! Good to know, my repair manual didn't mention anything about it so I just wanted to check.
  1. ls1 crow cam and vacuum reserve tank 4 sale
    By dijm8 in forum Parts And Other Items For Sale
    Last Post: 09-11-2008, 07:29 PM
  2. cooling system question
    By seans VL Calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2008, 08:18 PM
  3. My Cooling System... Help
    By Explosions Hurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2008, 09:03 PM
  4. Coolant stuck in reserve tank
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2006, 10:15 PM
  5. why does my reserve tank always drop
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2005, 10:03 AM
