Results 1 to 14 of 14
Thread: oil/trainsmission leak
    Commodore vs Wagon
    Jul 2009
    Exclamation oil/trainsmission leak
    hey guys
    i have a vs 97 wagon
    i noticed for a couple of days now abit of trainsmission fluid leaking and oil drips its like a small/medium size of a day but i changed the oil and it now looks like the red colour fluid so im assuming transmissin
    please help how can i stop it i cant find were its coming from
    but the oil looked like it was coming from the oil filter but i have tighten it now
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    powers teering pumps are notorious for leaking on almost any commodore, they also have tranny fluid or p/s fluid is the sam pretty much anyway. Check that. If not, tranny fluid should be in the centre of the car aor it could be the tranmission cooler lines.
    Commodore vs Wagon
    Jul 2009
    VQ Caprice II
    Aug 2006
    it can also be the "speedo fitting" on the side of the transmission, usually the "o" ring perishes, or the housing cracks, not expensive to change.
    power steering lines can be tightened, sometimes they leak from the seal under the power steering reservior. Small "o" ring.
    also the steering racks tend to leak from inside the dust boots, you can have the steering rack re-built in most states about $300, or find a good second hand one .
    best of luck
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    My vy was leaking around the sump gasket on the tranny. Check all around the edges of that as well as what the other guys have said.
    If it's that, then you need to buy a transmission service kit, but search first or ask questions if you've never done one before. Good luck.
    Commodore vs Wagon
    Jul 2009
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    40 odd bux plus transmission fluid, decent mechanic shouldn't sting you too much but you need to make sure that the leak is actually from the transmission sump. Like said above it could be power steering, etc.
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    if it is the lines, you dont change them its usually a loose fitting or clamp as they are under pressure, get underneath wipe whatever you can see clean and pinpoint where its coming from.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by shiftySLE View Post
    Yeah I had to do up a clamp on the steering fluid line on the vy.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Mine had a leak a month ago, turned out to be the trans front seal / O ring seal.
    Had that, the pump seal and clutches all done at once, hasn't leaked a drop since.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    Commodore vs Wagon
    Jul 2009
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Wasn't cheap. Cost me $500 including labour (cheaper rates through my mechanic as it's his friend who works at the trans place i take my car to) as i had the clutches etc done too.
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    That does sound fairly cheap, if the clutches were done as well, that mean all the internals were taken out, almost a rebuild.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Yeah i get suprisingly good prices through my mechanic on certain things. But some places he uses for certain jobs, the prices are expensive, and there is no mates rates.
    I was happy with that price. Feels a bit better to drive. I'd love to throw $1800 at my trans and get all the stuff done that i could, but can't afford to do that with buying a house. Not realistic.
  1. about that oil leak..
    By aella in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2008, 09:00 PM
  2. Oil Leak..
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-11-2008, 08:07 PM
  3. VS V6 oil leak
    By mcvk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2007, 03:34 PM
  4. Vn Leak!!!! Help
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 08:05 AM
  5. Oil Leak
    By mikemutlow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2006, 06:43 PM
