hello i am after some help i was driving my vs today and my oil light came on the oil is full i have only just done a oil change i turned the car off then starter it after a few min it has no come on just yet any one know what to look for as to y it happend thanks
were you driving it hard up in the high revs
There is no such thing as stupid questions, Only stupid people.
oil pressure switch???
were the oil filter is there is like a electrical switch if there is oil dripping from it then it needs to be unscrewd out with a spanner and you can go to bursons and it should be about 20 bucks, if there is no oil dripping then i reackon its a electrical fault
mine comes on if i break to hard going down hill then goes out after a bit spun me out the first time it happened but used to it now, i know it is burning oil cause the vavle stem seals are buggered, so i check it once a week or so and top it up if it needs it.
see how that goes use a big spanner not sure on the size and tack out the switch and replace the sensor and let us no light shouldnt be on then
