Results 1 to 5 of 5
Thread: couple of VR problems
    VR Berlina 3.8l Buick
    Dec 2008
    Horsham
    Default couple of VR problems
    Hey guys just had the transmission and exhaust replaced in my VR with second hand factory items but there are a few more problems I need to deal with and am looking for advice. There are a lot of random noises - the front suspension has a lot of creaking and crunching from it, and there is a gurgling noise like water flowing behind the dash. Also in my dash cluster the fuel and temp gauges don't work properly or have lights, and the trip computer beeps at me every time the AVG speed changes. Also the piece of the under-dash that covers the fuses has broken clips. My question is what are these problems most likely to be, and how much will they probably cost to fix?
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    suspension - cost depends on what is actually wrong. could be shattered strut bearings, swaybar links, tie rod ends, control arms, ball joints.... there's a fair bit could be stuffed
    gurgling noise behind dash - bleed cooling system. when engine is warm, pop bonnet. on thermostat housing is a small screw. undo this. air will rush out. tighten screw when coolant flows out. cost = $0
    dash - depends. if the needles are just sticky you could pull it apart and clean with prepsol, but if the senders or gauges themselves are stuffed....
    as for the fuse cover clips, scab some from a wrecker
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    vr 5 speed
    Oct 2003
    if you don't mind doing it when the gauges get stuck again give the dash abit of a wack.. if there abit sticky they should pop up to where they need to go.. if not it's your senders.
    p.s i have never done this to my car
    I don't stay with my my wife for love, spite really, i won't leave her cause that'll make her happy!!
    Dec 2008
    Horsham
    Yeah the old dash whack works but the lights out behind it are still a pain in the arse. And the beeping... Thanks for the help with the gurgling, Forgotten
    Dec 2008
    Horsham
    Any other ideas? Specially on the beeping?
  1. just a couple of problems with the VZ sv6
    By AntonioC in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-08-2009, 11:31 AM
  2. A Couple of Problems, AirCon and Cruise Control
    By b3h3m07h in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2007, 09:47 PM
  3. Couple Problems
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2006, 06:05 PM
  4. Couple Of Problems ....
    By ElDubya in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2005, 09:44 PM
  5. the old couple
    By wildss in forum Jokes/Humour
    Last Post: 25-03-2005, 05:00 PM
