Results 1 to 13 of 13
Thread: motor oil leaking bad
    VR-S series II
    Jul 2009
    Darwin
    Unhappy motor oil leaking bad from bellhousing - help
    Hi everyone ive had trouble with my auto replaced some seals, filter and fluid. just put the gearbox back in and started the motor after about 3 - 5 min (idle) i noticed a smell it was oil dripping out off the bellhousing on to the exhaust and it just kept getting worse.
    the oil is black & runny the motor is due for a oil change could this be the problem
    My dad said maybe its cause the front was up on ramps for ages and the oil in the motor went towards the back
    i dunno
    (it didnt do this before i took the gearbox out)
    Any ideas welcome
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    sounds like its leaking out your rear main seal on the crank. Did you touch anthing around there when you were playing with the box ?
    VR-S series II
    Jul 2009
    Darwin
    Post
    when i did the gearbox all we did was pull it off change the seals on the box and put it back in. Ive done gearboxs before (this is my first auto) and never had this problem
    if its the rear main the motor needs new oil will it help to change it also what oil and is there somthin i can put in the oil to help seal the leak
    please need help
    VR-S series II
    Jul 2009
    Darwin
    BUMP sorry but i really need help
    someone anyone any ideas or suggestions?????????????
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    if its the rear main, just take the box out and do the seal if its not the rope type, you could try some real thick stuff to slow it down, but its a bit of a quick fix and if its that bad, it wont work anyway.
    VR-S series II
    Jul 2009
    Darwin
    Quote Originally Posted by shiftySLE View Post
    thanx for reply
    what type of oil is best and is there somthin i can put in with the oil to help the leak it just makes me made that i just had the box off
    greenacc's Avatar
    VE Berlina
    Jul 2008
    there are plenty of stop leak products for engines...and the thickest oil I would use is 20W60 but its not going to help much...
    VR-S series II
    Jul 2009
    Darwin
    Quote Originally Posted by greenacc View Post
    thanx for ya help
    im gonna try new oil and some of that stop leak stuff
    any suggestions on what brand of oil and stop leak???????
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    If the engine is in decent condition besides the leak, DON'T use stop leak, It clogs the system to a point where the oil is like a slush, it will cause more friction in the engine and is no good for cams and...well anything in the car. Once the heat is up, it will probably leak just as much. Get the leak fixes. Stop leak is just like a chemweld for engines, its a quickfix which will cost more in the future if you are keeping the car. I used it in the last engine just to get me by a couple of months and it went downhill quicker than ever.
    VR-S series II
    Jul 2009
    Darwin
    i got sold a LEMON one problem after another time to quickfix and sell, i dont have the time or money to deal with this ill let someone else deal with it its nasty but im ova this car
    what brand & type of oil should i use also what brand of stop leak
    Any suggestions welcome Cheers all
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Penrite HPR 30 is 20W60, or look for an oil that claims to be for old engines , they are usually quite thick too. but remember its going to do sweet fa. nothing will block a leak if there's a gaping hole in your gasket. Get under it and get some silastic into it.
    vt s s1
    Mar 2009
    VR Berlina S2
    Aug 2009
    Mine is doing the same thing, but its the Power Steering pump leaking, its all over the exhaust, also drips from K frame.
  1. rebuilt motor and have coolent leaking out of the exhaust manifold help plz
    By BENJAMUM in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-05-2009, 09:50 PM
  2. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  3. wanna swap s1 motor for a s2 motor in a vn
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2009, 05:55 AM
  4. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  5. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
