Results 1 to 7 of 7
Thread: VR Vertical Bonnet adjustment - Help needed
    1995 VR Series II S
    Aug 2007
    Red face VR Vertical Bonnet adjustment - Help needed
    Hello everyone, I'm looking for some advise on how to raise the back (windscreen end) of my bonnet, the back sits below the fender line. Most cars can be raised by loosening the two bolts on the guards and raise the hinge, but my VR won't move. I've removed the bonnet & brackets but the adjusting plate won't move, it's not rusted or stuck as I can move the plate in and out from the guard, just not up and down. Would appreciate any help thanks
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    1995 VR Series II S
    Aug 2007
    Wink
    Quote Originally Posted by seraphic06 View Post
    Maybe you could place some washers between the bracket and the bonnet?
    Thanks for that, I'll keep that idea for my last resort, But I think I'll keep looking at why the adjusting bracket does not move. Hopefilly someone may have a workshop manual photo of what's holding the bracket in place. Cheers
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    the little black plastic adjusters towards the back on the fenders may help.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If the bonnet is sittling lower than the mud gaurd - your hinges are bent. Get some lube on them before they bust your front window.
    Replace the hindges to see the bonnet back to the gaurd level.
    and 3 Dangerous non ABS VN's
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    hey mate, i also have the exact problem, hasnt concerned me yet but if anyone has an answer... i've also been told to put washers in... but dont really want to....
    it's exactly how you describe your problem...
    and the black adjuster's arent much help...
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by S2_VR_ View Post
    It will be bent hinges that lets the bonnet drop down at the back. It's no real problem until it cracks the front window.
    Lube hinges now
  1. Vertical lines thru projector
    By Torquative in forum The Pub
    Last Post: 07-10-2008, 04:43 PM
  2. Help needed with bonnet - Urgent!!
    By bink in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 04:50 PM
  3. Bonnet release cable HELP NEEDED!
    By shrekVK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-11-2006, 11:21 PM
  4. bonnet adjustment
    By spice_man2069 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-08-2006, 07:17 PM
