Anyone seen this before ???? At idle and in gear (auto) the instant L/100k's display jumps all over the shop, but once you start driving it reads like it should. It's a new event in the last few months with the wagon so I'm guessing a faulty sensor![]()
Mmmmm V8
I think that's normal. For me at idle it doesn't display anything.
I have the wags for around 8 years now and I'm pretty sure at idle it sat at "0.0" though rapidly reaching old age I could be seeing things !
Mmmmm V8
at idle in gear mine does it to
my 1996 vs berlina
http://forums.justcommodores.com.au/...s-berlina.html
Yes, but that's in gear. Does it do it when it's in neutral?
my 1996 vs berlina
I'll let you know.......
Mmmmm V8
Ummm, you have a level 3 cluster yes? Do you have it set to average per kms, or the other setting? One calculates as you drive depending on speed, one re calculates every 100 km's.
Or do you mean on the normal per 100 km setting it's being erratic?
Originally Posted by wikky
Being a Berlina Cobez, I'm assuming he has the level 3 cluster, and is referring to the Instantaneous reading. If so, it should read 0.0L/100km if in netural, park or any gear WITHOUT moving. When the car moves of it's own accord (in gear, no foot on brake) OR if you use the accelerator, it'll give you instant readouts of what fuel you are using per 100km.
CruznCalais
[GAMBLR]
The VZ is here! About time!
Yep, it should read nothing whilst not moving. Even on mine when you have it on the instantaneous setting and you slow down at the lights it drops then when you stop it sits on 0.0L/100km.
ive had mine read like 11l/100lkm's sometimes but its only happened like twice when ive been at the lights completely stopped
MY RIDE - BAGGED CAPRICE
http://forums.justcommodores.com.au/...s-caprice.html
OK took the wagon out tonight to get some cheap petrol (Adelaide is cheapest Tuesday/Wednesday) and watched the instantaneous display and it goes like this.....
In gear and standing still, it flips between 99.0 and 0.00 L/100kms.
In neutral, it flips from any where between 60 ish to 99 L/100kms.
Go figure![]()
Mmmmm V8
Hmm then my guess would be some form of sensor is worn out. I have no solution though, sorry :P
CruznCalais
[GAMBLR]
