Hi fellas.
Come home yesterday and parked the VR Acclaim,everything fine .
Went out again 30 mins later but the key would not turn the ignition.(no evidence of attempted theft))
I also noticed the steering lock is not working as you can turn the wheel as far as you want with no key.
From memory ,my old HQKingswood ignition switch turned a pin that slid into a slot on the steering shaft,jamming it .
Are these more or less the same?
Can I get in there and fix it or does it need some special tools/knowledge?
If I have to,Ill get someone to have a look at it ,but I would like to be armed with some info before I have to pay anyone.
Any ideas? Does it happen often?
As far as i can tell, the only time my ignition barrel locks up is if the steering lock is on... And you just have to turn the wheel a bit to unlock it. I'm guessing some of the mechanics in the column have 'gone to a better place'.
I've had to replace 2 ignitions/locks now when both for not reason locked up and wouldn't let me in?, Instead of spending to much money I simply brought another from the wreckers for $20 & it went in pretty easy, apart from the piece that goes around the steering colum, had to cut with angle grinder. The only problem with doing this is you now have 2 keys, one to get in and another to start it.
