Results 1 to 4 of 4
Thread: Can you replace a 885 LUX BCM with a 795 Hi?
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Default Can you replace a 885 LUX BCM with a 795 Hi?
    Hi
    The Body Control Module in my car has been playing up for some time now, Immobilizer wont allow the car to start some days, and other times you press the remote to lock it and then it then the locks go down and straight back up until you lock it with the key.
    So I was wondering I have found plenty 779 Hi's but cant find any 885 LUX's which is in my car since it is a VR Berlina. So I was wondering could I use a 795 HI since it has the same functions as the LUX Body Control Module. I know that I need to change the key head etc.
    Thanks for any help
    Shane
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    Im pretty sure the connections are different due to extra crap in cars with a "HI" BCM,ie calais and stateman sorts.
    WTB:VR/S HSV 250km/h speedo cluster
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    more then likely only thought the difference was the brake light warning, as LUX and HI both have Climate control, windows, anti theft etc
    Just so hard to find a LUX BCM its near impossible.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by hsv91ss View Post
    Hi
    Thanks for any help
    Shane
    hey mate, i dont know much of the differences between the models as in pin outs n plugs, but the options are the same, if they both have the same plugs HI has 3 i believe, LUX i dont know, u could try it with the matching key.
    the other thing, u could repair ur BCM, i can garrantee it'll be dry solder joints, i would disassemble and just quickly run over the joints with an iron n maybe a touch of fresh solder too.
  1. How do I replace the fan
    By Radarboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2009, 09:02 PM
  2. How do I replace the AC fan? VS
    By Siggers86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2009, 02:28 PM
  3. manifold.. much to replace ??
    By Nicks in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2007, 10:57 PM
  4. HOW TO replace headlining
    By tsimira in forum Holden Commodore How-To's
    Last Post: 01-02-2007, 03:38 PM
  5. replace panels
    By commy84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-10-2005, 03:39 PM
Tags for this Thread
