Results 1 to 11 of 11
Thread: VS V6 Clicking sound when turning
    N/A
    Apr 2009
    VIC
    Default VS V6 Clicking sound when turning
    My VS V6 makes a clicking sound when turning left. Not 100% what i need to replace.
    vn calais
    Aug 2009
    northern burbs
    bearing tops! 100% there like $5 from all auto parts places and the sit on top of the strut before it couches the body at the front!
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    also if that doesnt fix it, try checking your diff... sometimes the internals of a diff "chatter" when worn
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    does it click when braking or hitting bumps or only turning left?
    VR Acclaim
    Sep 2008
    Kingsley WA
    Check to see if any of the rubber bushes at each end of the stabiliser links (attached to the stabiliser bar) are missing.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Check your steering rack and tie rod ends. The bushes will probably need replacing as well.
    VR Commodore
    Apr 2009
    Check your tie rod ends. Might have play in the ball joints. To do a quick test, turn the motor off and with the wheels straight ahead on firm ground, move the steering wheel side to side. You shouldn't feel or hear any noise or have much play.
    VS exec
    Jun 2009
    bong from the gong
    N/A
    Apr 2009
    VIC
    VR Commodore
    Apr 2009
    VTBEAST's Avatar
    VTBEAST is offline LOVE THE VT BEAST
    VT Executive 3.6 injected V6
    Sep 2009
    GREENVALE
    if u got hubcaps check dat its on tight it happened to me when ever i turned
  1. weird clicking sound and other issues
    By zaprat in forum Electrical Wiring / Questions
    Last Post: 01-08-2009, 06:26 PM
  2. Creekingroan sound when turning need help
    By Jemmo5ltr in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2009, 02:14 PM
  3. VS clicking sound rear
    By combatantsomeone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2009, 06:31 PM
  4. HELP !! metalic clicking sound...
    By mattakaspeeedy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2007, 05:14 PM
  5. Power Window (Just 1) Seized up. Clicking sound from inside dash.
    By MikesVT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-01-2007, 05:21 PM
Tags for this Thread
