Looking to mod the variable int wipers into my exec. So couple questions.
1. Does the mid BCM have the capability's inbuilt to automatically run the variable int wipers
2. Does the exec wiring harness have the extra wires for the variable int stalk.
If not im gonna try and dream up a trigger cct and wire it all up manually. Other option is try and modify a hi bcm with my imobiliser.
Is there a way to take the imobiliser bit out of my bcm and put it into a Hi bcm so i can retain my key and i can just plug it all straight in.
