Results 1 to 6 of 6
Thread: VR Oil sump leaking!
    VR Commodore
    Jun 2005
    Default VR Oil sump leaking!
    hello
    i got leaking from oil sump. as just replaced rear main seal when tranny got rebuild!..
    so i have to take the cross member off as i need to remove oil sump?
    what recommend gasket glue do i need to put it on to stop leaking as this much??
    does they sell Oil sump gasket (like paper or somethings??)
    cheers
    Holdenrocks
    VR Berlina S2
    Aug 2009
    They make gaskets, but there cork.
    What i found was good, and its what i use, Loctite Gasket Maker. Its about 50 bucks from autobarn.
    And its Oil Resistant, Coolant Resistant, and Temp. resistant. works a treat!
    selling vp calais wheels with 97% rubber hardly used!
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    i use Loctite Blue RTV [smurf-spoof due to the blue colour ] for all my gaskets im in need of...
    i use it on Thermostats, water-pumps, exhaust gaskets, etc etc
    good shit, only about $15-20 from Repco or Autobarn...
    VP Exec
    Jun 2005
    I'm with the blue RTV or the Permatex branded Utra-Blue equivalent.
    holdenrocks, are you sure that the leak isn't between the bearing cap and the block? On the cap parting line, use a thin smear of Loctite 515 and the Ultra-Blue squeezed into the grooves.
    Yes, the K-member has to be dropped to get to the sump.
    VR Commodore
    Jun 2005
    yea, just oil sump pan gasket leaking.. as i can see it under the car... thanks for the help cheers
    vs exec
    Sep 2009
    Hi, no need to remove crossmember on a vr. undo engine mounts and jack up the engine as far as it will go without the throttle body denting the firewall and you have just enough room to remove the sump. 2 gaskets are available, (cork and rubber) only use a cork gasket. no sealant required. do not use a rubber gasket. just be carefull not to overtighten the sump bolts. if you have a manual that should give you the torques for the sump bolts.
  1. Leaking Sump Plug Fix?
    By Ozzie in forum General
    Last Post: 20-01-2009, 10:20 AM
  2. What is it? under the oil sump....
    By AlpineRaven in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2006, 05:30 AM
  3. oil sump
    By vpdood in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2006, 08:39 AM
  4. RB30 leaking sump
    By Decksta in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-07-2006, 08:51 PM
  5. leaking oil sump
    By Melville P Lazaro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2006, 10:42 PM
