Hi there
I was just wondering if you need the heater tap to pass a roadworthy inspection in qld because mine just brokebut i have just bent the hose back into engine for now so i don't loose coolant.
yea the heater needs to be working to pass
they're not expensive and are easy to change. u will need to top up ur coolent after the change, but nothing major, will cost you around $30
im no expert on what pass's and what dosnt, but i have seen dozens of cars that pass e inspections with heater hoses plugged off.
But they shouldn't, because the windscreen demister no longer works.
yes but to pass a legit roadworthy, it needs to be operational. i know there are some out there that will pass some of the smaller issues, will be a hit n miss with them, its only money at the end of the day if u fail..
Harden up and just fix the heater tap, its cheap and easy.
