Results 1 to 8 of 8
Thread: Alternator internal electrical diagram
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    Default Alternator internal electrical diagram
    hello everyone, pulled apart an alternator i got from a wreckers, and i pulled it apart only to find that the stator had wires running to the magnetic coil. does anyone have a diagram or know where they go
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - Cooled L67 + T56 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    stator should be terminated onto rectifier, through diodes... which magnetic coil do you mean? the rotor?
    VR 3.8L
    May 2009
    na the big cylinderical copper thing the rotor slips into, its soldered to the diode pack at the back of the assembly
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    ???Not sure what your talkin bout, but im sure they are setup just like a 3 phase full(or maybe half wave) wave rectifier. Google that up for a pic and you can prob guess whats goin on
    Reaper
    VR 3.8L
    May 2009
    its kinda hard to explain... i mean the stator (big copper thing that the rotor slips in) is soldered to the retifier assembly (diode pack). when i pulled it apart two wires were broken. would it matter where they solder onto. would polarity matter as they are diodes and only allow electricity flow in the convention way.
    VrWagz1's Avatar
    May 2008
    wollongong
    yes it will matter and you may damage your battery, ecu, insturments, if you get it wrong ans you will put AC through everything. If they are unmarked then it is going to be tricky to tell where they came from, i see your dilema.
    I'll add these attachments of rectifiers i have and one of them should be somwhat similar to whats happening in the stator windings so you can see. My guess is it will be a half wave that has 3 diodes because the alt usually only has 1 active wire going to the battery. If it has 6 then it will be one of the full wave pics. In the pics imagine the resistor/load as the battery.
    If it has 4 diodes then its a single phase bridge rectifier, google that for a pic, but unlikely it is single phase.
    If you can find a star point and the ins and outs of the diodes then you should be able to meter it all out ok. If it is a halfwave 3 phase the output where the main out wire would bolt onto is where the common for all the cathodes(blocking side) of the diodes are
    Hope this makes some sort of sence???????
    Edit, it can also have more phase's ect, ike it can be 6 phase half wave too(so for the half wave one just imagine another 3more diodes in there with 3 more windings attached ect...), it dosnt have to be 3, it depends how many wires you have hanging out there, i have never pulled one down to see so im shooting blind here.
    Attached Thumbnails Attached Thumbnails Alternator internal electrical diagram-3fwdelta.gif   Alternator internal electrical diagram-3fwstar.gif   Alternator internal electrical diagram-8273y012.gif
    Reaper
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    VR 3.8L
    May 2009
    those pics are a bit too schematic ish... i just needed help with soldering the rectifier/diode pack to the stator... the stator has 6 wires that were soldered to the rectifier and i broke 4 getting it out and i cant remember where they go
  1. internal led lighting
    By park0 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-07-2009, 03:14 PM
  2. VN electrical problem alternator dead X2
    By combatantsomeone in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2009, 05:33 PM
  3. Leaves in internal fan on VR
    By alexjhobbs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 10:41 PM
  4. Electrical diagram for a VB SL 253 series 1
    By jd hot stuff in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-09-2007, 08:01 PM
  5. Internal Fan (blower?)
    By elbows in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2005, 07:20 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
