Results 1 to 14 of 14
Thread: Identity Crisis
    Gudgeon's Avatar
    Gudgeon is offline NE1 4SX
    VR Exec S2 and VK 333 Pack Calais
    Jul 2008
    Mount Gambier
    Default Identity Crisis
    hi all,
    i have a 95 vr executive. I.ve found a loom what looks to be for relays under my steering column but its empty. Theres a 5 pin one and 4 pin one was hoping someone could tell me what there for and alsoor what relays go in there. Norrmally open, normally closed etc
    thanks
    There's No Replacement For Displacement
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    at a guess the 5pin is for power windows..
    there should be some labels on it or numbers.. can u reference it to the sticker on the inside of that panel?
    Gudgeon's Avatar
    Jul 2008
    Mount Gambier
    Nah theres no sticker on the panel, the loom is just hanging around near the bottom of the steering column. Any ideas what size amped relay and whether it should be normally open or closed? Not sure what the other does. Some one must have the same loom in there vr.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    can you take a few photos of that area, we are really just guessing at this point.
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    The 5 pin one is the drivers window one and the 4 pin one is power window related or something that I cannot remember.
    The Vr and Vs are different in terms of wiring down there.
    Gudgeon's Avatar
    Jul 2008
    Mount Gambier
    thanks mate. Any idea what type of relay goes in there? Open or closed? thanks. Identity Crisis-03092009025.jpg
    Gudgeon's Avatar
    Jul 2008
    Mount Gambier
    i just noticed that i didn't mention i've been doing the power window conversion, and cant get them to work. which is why i wanna know what goes in them plugs. door/console looms and switches from working donor car as are the regulators. and have increased form low bcm to mid bcm.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    they dont look like factory items, but kinda do. the relays under there are in the block with fuses. havent seen em outside like that.
    with ur power window conversion, do u have the metal contacts/pins in the relay and fuse spots according to the sticker on ur panel there? if u do follow this: cant get windows working
    if u dont have the pins/contacts, follow the how-to in the how-to section, i believe its a sticky
    VS Berlina 3.8
    Dec 2008
    ...The post I quoted seems to be missing... Disregard.
    Brett is offline Legend
    VR V8 Ute
    Jun 2003
    Gladstone, QLD
    Both of them are for your power windows.
    Make sure you you get the right relays for them Especially the 5 pin one
    If your doing the power window conversion checkout all the threads on here they offer some good info.
    jujibelly's Avatar
    Vr Commodore
    Apr 2009
    Melb
    For the 4 pin relay just use the same relays that are in the fuse panel.
    For the 5 pin one you need to go to Holden and order in a drivers window relay which costs $23.
    I tried all the 5 pin relays from commodores but all blew the fuse, the 5 pin fuse from Holden has different circuitry.
    Ephect this is factory on the VR hence my comment in the other thread about power windows. The VR and VS have different wiring.
    VR V8 Ute
    Jun 2003
    Gladstone, QLD
    Did you try the metal relays in fuse box under the bonnet? they have the correct pin outs.
  1. VT II Berlina LS1 with an identity crisis
    By RavenLS1 in forum VT - VX - VU - WH - V2
    Last Post: 05-02-2011, 12:01 PM
  2. Identity crissis
    By Snerty in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2008, 10:23 PM
  3. 1992 Vp Fuse Identity Numbers???
    By Cobez in forum Electrical Wiring / Questions
    Last Post: 01-05-2007, 10:17 AM
  4. Identity Tags
    By Brasstard in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-01-2006, 08:55 AM
  5. The Crisis
    By SCUMMY in forum Jokes/Humour
    Last Post: 16-10-2003, 09:15 PM
