Results 1 to 2 of 2
Thread: Strut brace for VR ute compatibility?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Default Strut brace for VR ute compatibility?
    Will a Strut brace supposed to be for a V6 VR-VS commy fit a V8 VR engine or are the engine clearances different? For some reason there seems to be about 100 dollars difference between the two apparently.
    edit: also thinking about it, I can kill two questions in one thread here, should a motor with a clutch driven fan and not a thermo come on immediately at ignition and stay at approximately the same speed regardless of temp. (except when revved) all the time?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    i think they are different because of the clearance
    Yes clutch fan stay same speed at idle as thats when you need it cooling. When you are driving and reving ect.. thats when you dont need it as forward motion moves the air through the radiator. Ifyou hold your foot down at about 2500rpm you'll hear it cut out.
    Reaper
  1. Strut Brace
    By INDACLUB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2010, 11:59 PM
  2. Strut brace
    By one_and_only2004 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-11-2008, 10:45 PM
  3. Wtb Vr-vs Strut Brace....
    By sedate looking in forum Swap / Wanted to Buy / Trade
    Last Post: 17-03-2008, 05:12 PM
  4. Rear Strut Compatibility ?
    By Fletch_QLD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2006, 09:47 PM
  5. Strut Brace
    By B£å¢kÐðg in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-01-2006, 09:07 AM
