Results 1 to 10 of 10
Thread: !!ultra lows on front and back???
    vr executive
    Nov 2008
    Default !!ultra lows on front and back???
    hey guys
    i got a vr executive with 15 inch interceptors on it and im wondering wheither i should get ssl all round or ultra lows all round. i wont both front and back tyres to be under the guard but the back a touch more than the front. also would i get a very bumpy ride with these springs? or is that just with chopped springs?
    cheers jordan
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    you cant get ultra lows for the front, the lowest you can go on the front is ssl's....
    if you want a nice stance, i suggest ssl's front and sssl's for the rear..
    seeing as u have a vr exec, im pretty sure they are live exel, so it wont go that low compared to a IRS...but ssl's will get you about 10-15mm above the tyre and sssl's will get you to 5 to -10mm above and below the tyre...
    there is also the dodgy way of cuttin a few coils off the spring..
    when lowering any car is gets bumpy, as the springs are thicker...fitting some lower shocks helps a little bit..
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    vr executive
    Nov 2008
    ohk
    arnt sssl,s the same as ultra lows?
    and do u meen 10-15 and 5-10 mm under the guard?
    cheers mates
    Troy5L's Avatar
    Jun 2005
    yeh sssl's are ultra lows, ssl's are super super lows and sl's are super lows..
    10-15mm(with the ssl's) would be the gap between the guard and tyre
    (sssl's) 5mm the gap between tyre and guard to 10mm tyre tuckage..
    if you end up getting SSSL'S and want to go lower you can do the safer way than chopping and get the springs reset..which you take it to a place(not sure where, maybe suspention place) and they heat up the spring and compress the spring to a desired size...but you can only go so low, because of bumpstops and the police lol
    My VS CLUBBY!
    vr executive
    Nov 2008
    wow thats wierd
    i have sl's in the back atm and id say thers about a 30mm gap between the tyre and guard. my cousin has ssl's in his vt and hes sits about 5mm under the guard. i know his has irs but still i thought ultra lows would put me easily 10-15mm under the guard
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    Vy Sv8
    Jun 2009
    96 VS & 5spd VT 5.0L VX Clubsport lookalike
    Jun 2008
    Port Macquarie/Newcastle, NSW
    and as for getting springs reset, i tried every place i could think of where i live and nobody would do it....would love to know who actually resets them
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Seriously heaps of you guys still have no clue what your talking about when it comes to springs especially Kings as there is so much variation between lows, super lows and ultra lows.
    VS Acclaim S2 V6
    Jan 2009
    if your in melbourne try Spicers springs (i think google or 1223) in bayswater they make springs and reset them for you too i had super lows in the back of my vs w/irs wanted it tucking tyre, you can now see half the tyre tuckin on 235/40/18s and in drive its a lower and only cost $60 i took spings out myself and brang em in, if you get them to take springs out and put them back in once reset it will cost you bout $130. had to get an alignment and adjust the prevoius camberkit cause camber was pretty out.
  1. [VIC] swap VT-VZ REAR ultra lows for super lows
    By jimmyd17 in forum Swap / Wanted to Buy / Trade
    Last Post: 23-05-2009, 12:24 PM
  2. [VIC] Super lows & ultra lows
    By somerandom in forum Swap / Wanted to Buy / Trade
    Last Post: 29-01-2009, 04:49 PM
  3. Swap: super lows for ultra lows - VN sedan - in Perth
    By savage1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-08-2008, 12:47 PM
