Results 1 to 5 of 5
Thread: VS Electric Windows
    Nato B's Avatar
    Nato B is offline 95' VS Vacationer
    VS Vacationer
    Mar 2009
    Kadina, SA
    Default VS Electric Windows
    hey guys im having trouble with my front drivers window.. i can put it down but it wont go back up? any suggestions?
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    Switch maybe? Pull it apart, un-ground the relevant contact and see if that helps...
    I've also heard spraying WD-40 in them fixes switch problems occasionally? Can't guarantee that though.
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Does it at least try and get back up? Theres a good chance its the regulator
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    Did you recently put the power windows yourself? If so make sure to have a driver window relay.
    If not remove the door trim and pull the connector that connects into the regulator. Get yourself a battery and put two cables in the regulator (Where the plug came out) and hook them on the battery, reversing polarity will enable you to make the window go up or either down.
    If the window does not go back up with the method above, this suggests your regulator is stuffed and that you need a new one. Because you bypass all other possible causes eg switches, wiring etc
    Brett is offline Legend
    VR V8 Ute
    Jun 2003
    Gladstone, QLD
    Check the 5 pin relay near the steering column
  1. VT electric windows
    By -Jonno- in forum Electrical Wiring / Questions
    Last Post: 06-12-2009, 11:00 PM
  2. Electric Windows
    By wilca014 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-09-2008, 05:28 PM
  3. VT Electric Windows
    By crowzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2008, 04:53 PM
  4. electric windows
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2007, 04:00 PM
  5. Electric Windows
    By luvmycommodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2006, 08:29 PM
