Results 1 to 9 of 9
Thread: Issue when accelerating, HELP please
    VS Series 2 Wagon
    Feb 2008
    Eastern Suburbs, Sydney
    Question Issue when accelerating, HELP please
    I have a VS station wagon.
    Starting the car is fine, stopped at lights is fine, gentle cruise is ok… but under acceleration the car shudders. Freaked me out when it first happened as I was trying to overtake someone at the time, and this issue only seems to happen when i accerlerate up any kind of hill or incline, although i havent driven it all that much as i have been overseas for a month and drove if for the first time on Thursday, this was the first time i noticed this problem. This problem wasn’t around before I left.
    Could leaving the car idle for a month in the cold but garaged do anything to it ?
    I have read a few similar posts on this site and guys have been saying that it could be the leads or plugs
    If it is.....can I replace them myself very easily
    Any other ideas of the cause of the problem
    Thanks for your help all
    Ac2026
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by ac2026 View Post
    Ac2026
    From the symptoms you described it does sound like plugs or leads, most likely a lead.
    The leads are easy enough to change on the passenger's side but a bit more difficult on the driver's side. I haven't had an ecotec for a while but I think I had to move the alternator to run the leads properly.
    MY RIDE
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    id definitely replace the plugs and leads. that sounds like your problem.
    with some simple tools and a bit of know how you can easily do it yourself.
    just pull off one old lead and replace it with the new one of the same length from the packet.
    and plugs just screw out and you screw the new ones in. you should be able to get the plugs and leads for around 80 dollars. maybe less
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    95 vs calais V6 Auto
    Aug 2009
    Dora Creek
    i dont know if its the same thing but my old vl started to do it, i hadn't serviced it for 2 years, so i did the air, oil and fuel filters, changed the oil and did the plugs and it went like new again.
    Vs Acclaim s2,Vz Svz
    Aug 2008
    Rouse hill , NSW
    Ive had the same problem a few months ago,it happen maybe about 5-6 times over a couple of months. I havnt replaced the leads or plugs yet and the problem has just gone. Im planning on replacing the plugs this weekend though!
    MY06 VZ SS 6.0 TUR(i)SMO
    May 2006
    Hastings
    definately leads. had the same thing happen to my vr wagon
  1. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  2. VS backfiring when accelerating
    By charjon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2007, 06:05 PM
  3. Vr Stalling when accelerating
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2005, 08:00 PM
  4. Accelerating (RPM)
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 11:21 AM
  5. vibration when accelerating
    By vneom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 01:24 AM
