i have a 97 vs esteem and i am having problems with the heating
when i switch the heater on it will blow out a nice hot temperature for a solid 3 seconds before deciding enough is enough and blowing out the worlds coldest air, as i live in geelong and its around winter im sure you see my problem lol
any help is very much appreciated
Make sure you don't have an airlock by bleeding air out of the cooling system - undo bleeder screw which sits on top of thermostat housing.
Also check the heater tap is working - with engine warm, idling and temp dial turned to hot check heater hoses at bulkhead where they pass from engine bay to cabin - they both should be hot....maybe one hotter than the other. If not hot check heater tap vacuum - if vacuum exists then maybe heater tap is blocked. If you have climate control your heater tap may be different.
