Results 1 to 3 of 3
Thread: removing the a/c pump
    VR Berlina S2
    Aug 2009
    Default removing the a/c pump
    hey guys, i'm removing my a/c as we speak but i've ran into a bit of a pickle.
    One of the bolts that also has a bit of metal thats bolts onto the block, can not be removed because the hose end that bolts onto the block is in the way.
    so i was wondering, how would i go about removing it?
    ill get pic's if need be
    this is on a VR Berlina Series 2 with a Series 1 engine in it i think, V6
    selling vp calais wheels with 97% rubber hardly used!
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    are ya gonna be keeping the A/C?
    if so, you will need a thin 1/2" or 13mm spanner to get in beside the hose..
    if not, then cut it with a sharp knife....
    easy as..
    where abouts are ya? i might be able to help ya if in brissie?
    VR Berlina S2
    Aug 2009
    I'm in vic.
    But its all good now, what i did was just unbolt the hose next to it enough so i could get a 13mm in there, worked a treat.
    thanks heaps anyway ^^
  1. Removing & Installing P/S PUMP VN/VP
    By jetspin_vn in forum Holden Commodore How-To's
    Last Post: 03-10-2009, 12:42 PM
  2. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  3. Removing Studs Holding Pwr Steering Pump, V8
    By deserthead in forum General
    Last Post: 28-02-2008, 06:23 PM
  4. removing fuel pump from vk calias v8
    By ported in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-08-2006, 07:51 PM
  5. removing innards from water pump
    By closer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-12-2005, 06:41 PM
