Results 1 to 3 of 3
Thread: Power Windows Problem
    VR SS S2
    Dec 2008
    Newmerella
    Default Power Windows Problem
    Hi all,
    i have just installed power windows to my vr sedan and all windows are working besides the drivers door. Its not the motor or the switch i tested that. I plugged a couple of standard relays under the dash and the drivers window goes down but not up... all other windows work fine. The auto down on drivers window is working but when it gets to the bottom it doesnt stop and blows a fuse. I have a mid bcm out of a vr clubsport. I was wonder i am missing somthing or is there a special relay for the drivers door that i need or missing somthing from under the dash.. car is a vr ss sedan.
    cheers
    Gudgeon's Avatar
    Gudgeon is offline NE1 4SX
    VR Exec S2 and VK 333 Pack Calais
    Jul 2008
    Mount Gambier
    Just done the conversion myself and there is a 5 pin relay for the drivers doors. it should be tucked under the RH fuse panel area. Make sure its a bosch one though as i had trouble using hella coz the pins are back to front.
    There's No Replacement For Displacement
    VR SS S2
    Dec 2008
    Newmerella
    Thanks for that. It was just a relay. Brought one from Holden. its called a driver window relay part no. gm-92030460 for $21.14. I noticed it is labelled on the box as a relay headlamp. Once i instsalled it all windows work fine even the auto down on drivers door.
LinkBacks (?)
  1. 26-09-2009, 08:59 PM
  1. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  2. power windows
    By soccerfreek_69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2009, 10:23 PM
  3. driver side power windows problem
    By Summer-Sickness in forum Electrical Wiring / Questions
    Last Post: 13-03-2007, 07:33 AM
  4. Power Windows Problem
    By Kramer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 02:38 PM
  5. power windows ...help
    By chris239 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-08-2005, 04:34 PM
Tags for this Thread
