Hey there guys, finally got my aldl cable running properly after building 5 of them (1 stupid resistor) anywys does anyone out there know what i can use to read the logged .alg data, i done a log of a 100km/h run for about 5 minutes and want to veiw data so i know what is getting lazy and causing it to run rich and few other probs,
ANY HELP WOULD BE GREAT, THANKS
EFI line have a computer program dont they, i could be wrong?
selling vp calais wheels with 97% rubber hardly used!
play it back in efilive or click export in efilive save and veiw with spreadsheet
thanks, does anyone know if you can use EFI LIVE as a permanant addon to the factory ecu, So that you can set cetain values and have the computer respond to them, As in RPM limiter and so on or will it do damage to the factory ECU, thanks
you can temporarily command stuff like a/f ratio and what gear its in and stuff but its pretty useless for anything but dyno testing and componant testing really
How temp are we talking, i Run my laptop not long ago with some changed setting being A/Flow, Timing adv, etc and also removed the 1,2,3,4 gear shift hold commands and it kept running till i stopped it 7-8mins later,
So in short just wondering how long before it time out, I also made sure that the command is set to repeat otherwise it only lasts 5 secs, thanks
well every time the aldl stops or you start the engine but they are pretty pointles like A/F ratio you dont want to command 13:1 everywhere all the time will suck gas and if you are boosted it would soon melt things same with spark you can command 20 degrees you dont want that everywhere. yes you can add whatever degrees to the timing so it changes everywhere by that amount but thats a bit the same you want more in some places not everywhere normally you lock it in 3rd with the 3rd gear lock for doing dyno runs and can add a few degrees and see the effects on the dyno etc but for the average joe blo they are of no real use apart from diagnosing issues with stuff and its pretty cool to show people too
delco have you looked at the VR VS setup in efi live 4? theres so many different macros. which one should i use when driving? the one i sent you earlier today was common dyno setup i think
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
any one that says engine data mate i use use the dyno tools one myself.so the cable is working all good then mate its good to know whats going on in there sure beats guessing .obviously had no issues figuring out the wiring with my colour codeing![]()
