Results 1 to 7 of 7
Thread: Neon lit footwell
    Matt02SS's Avatar
    Matt02SS is offline Donating Member
    VY SS + VY exec
    Jul 2009
    Port Pirie, SA
    Default Neon lit footwell
    What is the best way to light up the footwells in a VR with red lights? Also where to buy the best light to use
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    hook the neons into the courtesy lights. Red isint a great colour on your eyes lol
    Grennan's Avatar
    Grennan is online now Slayer of Stupid Threads
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
    The way I did it was pretty simple. I spliced a switch into the wires for the cigarette lighter, put the switch somewhere subtle. Ran the neon wires underneath the center console and the carpet.
    - Black Manual VX SS Series II -
    Stealth Mode Activated
    vs clubsport
    Mar 2009
    brisbane
    Why.............
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    VS Exec Series II
    Aug 2009
    Its a very good look when done properly. I wired mine to the door switches on either side so when u open the front drivers door only the drivers footwell light comes on and the passenger side door... well u get the idea.. looks great
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Excuse the noob question but i already have red ones in the vy via a switch. I would like to put some sort of white lights under there too but have them powered off the door switch for when i hop in and out of the car. I take it I would join on to a pos or neg from the door switch but which would it be? I read that the neg is the one that switches it off and on?
    BrAdAsS is offline Banned
    VX Executive A4
    Dec 2005
    Brisbane Northside
    this might be helpful for VT/VX executive / lo-level BCM owners, but if the VS is similar then read on..
    If you've hooked anything to the door pins you will find they work sweet until you close the door and whatever is connected to it gets 5-6volts from the BCM. It is a input for the BCM, you don't want to hook anything to it.
    All vt/vx with hi-level bcm's have Dual-Contact door pins that share common earth. This solves the above problem and the switch can be used for a earth without getting the 5-6volts.
    Take off the drivers sill/pillar, you will see the output wires/plug that you can tap into for a BCM switched Interior light 12v+ source.. orange wire for VX.
    Using a relay:
    pin 85 = BCM Light 12v output
    pin 86 = chassis ground
    pin 87 = direct to battery
    pin 30 = to light positive
    Attach Light negative to dual door pin switch.
    Use suitable fuse and thickness wire for the amperage of the lighting you connect and done.
  1. footwell neons
    By SAV_117 in forum Electrical Wiring / Questions
    Last Post: 09-09-2009, 07:47 PM
  2. footwell neons
    By Ratten in forum Electrical Wiring / Questions
    Last Post: 29-10-2008, 06:48 PM
  3. footwell led's help
    By vn_lexcen_s2 in forum Electrical Wiring / Questions
    Last Post: 19-09-2006, 11:44 AM
  4. footwell LED's
    By TI0350 in forum Electrical Wiring / Questions
    Last Post: 07-09-2006, 10:17 AM
  5. Leak in Passengerside Footwell
    By Bloka in forum General
    Last Post: 24-07-2006, 01:30 PM
